00 Civic - Where does hose for FUEL INJECTION AIR (FIA) CONTROL SYSTEM connect?
OG Tech
Hello, did a search but no luck. The engine is 2000 D16y8 and I have this hose that connects to the Air Assist Solenoid Valve(#24 in the picture). I was wondering where does it connect to?
OG Tech
Re: AIR ASSIST SOLENOID VALVE hose
Thanks for the picture, but now I am kinda confuse. lol. I must have the wrong intake pipe... There is that hole where the pipe/hose from the valve cover goes into and the plug. I don't see another hole or nipple on the intake for that FIA or AASV hose
You have the correct intake. The breather hose connects to the intake nipple to the right of the receptacle for the electrical plug and the FIA hose connects to the intake nipple to the left of the receptacle for the electrical plug (not visible in your picture).
OG Tech
Nope, just one nipple right from the receptacle. So, I guess I need to find an intake pipe with two nipples and one receptacle.
I have a 99 civic ex with a skunk2 intake manifold.. I have a similiar problem related to the fiac valve that hopefully someone can anwser for me please..I cnt seem to find what hose I'm supposed to tap into with a vacuum tee.. I need to find where the hose that comes out of the top of fiac valve belongs.. I know the stock manifold has an inlet between the two middle runners bt on the skunk2 they eliminated it.. so my main concern is where can I attach it to so that I can pass my smog cuz of of now it shows that its been tampered with...
what about the M/T housing doesn't have the air assist solenoid valve hose can you run a A/T car with out the air assist soleniod valve i just saw the diagram and i think i want to run it with out it and i was wondering
OG Tech
OG Tech
b/c the damn thing is 127 and i got the other thermostat housing unit with out the slot for the air assist solenoid and figured i can pull intake off at a junk yard or find one on craigslist and not have to worry about that part but i am not to sure if it is going to work out tho
Re: 00 Civic - Where does hose for FUEL INJECTION AIR (FIA) CONTROL SYSTEM connect?
hello i am looking for this part, where i can buy any? cheaper ofcoruse, i was looking in all junkers here in tampa, and i can not fine nothing, all honda civic vehicles do not have engine, regards
Technical Hero
Honda is pretty much the only one that makes it that I can find. So your only other options is find one on Craigslist on a part out car, ebay, or the marketplace.
OG Tech
This website might have it.
http://www.hondaautomotiveparts.com/
