00 civic keyless entry problem (solved)
Old 07-27-2014, 03:31 PM
k_ho's Avatar
Default 00 civic keyless entry problem (solved)
Hi guys
I just brought a 2000 Civic. I love it except the keyless entry won't work. I've been told by the seller it is because the battery on the transmitter. I changed the battery on it and it still won't work.
1. when i press any button on the remote, red light on the remote flashes but no response from the car side.
2. power lock on the driver door works perfectly: lock and unlock all four doors.
3. I tried to reprogram the keyless by on and off the ignition four time and press lock every time it 's on. I am sure i did it correctly but still no respond.
4. It came with the stock radio. radio works fine.
5. I checked the kick panel, the receiver is there!
6. One more thing, the car came with a security system handbook. Both the model for the transmitter and radio are different from the car.
The transmitter I have doesn't have a option button and the radio I have doesn't have a valet switch.The handbook refers to a transmitter with option button and radio with a valet switch.Is there anything to do with the nothing working keyless ?
7. please help !!! any thoughts ?
Old 07-27-2014, 05:49 PM
Former User's Avatar
Default Re: 00 civic keyless entry problem
What Civic trim?
The transmitter is correct for a 99-00 Civic.
Have you checked fuses 51, 30, and 14?
There are also control unit input tests that can be done with a multimeter.
Old 07-27-2014, 07:05 PM
k_ho's Avatar
1. the Vin# contains EJ6, i'll say it is a DX
2.fuse 30 and 14 check out. don't know where to find fuse 51. can't find it in the manual
3. I don't have a multimeter and I don't even know how to use it. but I did disconnect the unit and make sure it is properly connected.
Old 07-27-2014, 07:11 PM
EJ6 ---> it's an LX
2.fuse 30 and 14 check out. don't know why to find fuse 51. can't find it in the manual
Under the hood
You'll find nifty fuse box diagrams in the FAQs sticky.
If the problem is not as simple as a blown fuse, then you need multimeter -- less than $10 at Harbor Freight Tools
Old 07-27-2014, 07:30 PM
k_ho's Avatar
Originally Posted by RonJ@HT
EJ6 ---> it's an LX
Under the hood
okay fuse 51 check out.
So I guess I have to get a multimeter tomorrow then. seems like it's my best shot
Thank you
Old 07-27-2014, 07:33 PM
Do the input tests below. If you have any specific questions, post them.
Old 07-27-2014, 07:42 PM
yippee-ki-yay
eHMxhACk's Avatar
Thank you
From another thread:
Originally Posted by OptimisticWay
Or pick one up for free at Harbor Freight, NO PURCHASE NECESSARY!
http://www.dealsoff.com/harbor-freight-coupons/
Enjoy.
eH.
Old 07-27-2014, 07:43 PM
Old 07-31-2014, 06:22 PM
k_ho's Avatar
[solved]
Turns out I got a defected transmitter from the previous owner. Brought one from ebay for $27 and it works well
han8909227
07-29-2016 02:21 AM
re2417
16
06-07-2012 04:43 PM
DOUBLExDEUCEx22
07-28-2008 07:48 PM
CIVIC dude
11
05-10-2005 10:52 AM
Quick Reply: 00 civic keyless entry problem (solved)
