00 civic ex high rpm 2000 rpm.
Old 03-26-2013, 08:06 AM
AllAboutHonda's Avatar
Default 00 civic ex high rpm 2000 rpm.
High rpm while driving only, when the car comes to a complete stop the rpm stay at 2000 rpm and then after 3 to 5 sec it will drop back to normal 500 to 700 rpm and you can put it on gear and it will be crusing at 2000 rpm with out touching the gas paddle, shifting to neural rpm will go to 2000 rpm. It doesn't idle, brand new ICAV. Hopefully someone out there might have this problem before, any reply will be thankful..
Old 03-26-2013, 08:13 AM
If you loved me, you'd all sell me your magic cards to me today
doctorake's Avatar
Default Re: 00 civic ex high rpm 2000 rpm.
Manual or automatic?
Old 03-26-2013, 08:23 AM
I'm sorry, it's a manual a d16y8. Stock motor with stunk2 tb, manifold, and DC header.
Old 03-26-2013, 07:10 PM
that_boy_sammy's Avatar
sTunk2 tb? LOL it probably has to do with that. Look for vacuum leaks around it or change back over to the OEM tb. Make sure the cable is not sticking either.
Old 03-26-2013, 08:11 PM
JuggerNaut-CTR's Avatar
Vacuum leaks are generally from a pulsing/surging idle.
Clean all the sensors attached to the intake manifold. Then adjust the idle screw and throttle cable.
Old 03-26-2013, 11:45 PM
xile6's Avatar
Check for vac leak.
Then do the idle reset steps. You can google them.
Old 03-28-2013, 08:30 AM
Alright I'm gonna put the oem tb back see what would cost that. There isn't a idle screw on the tb cause its a s2 tb...
Old 03-28-2013, 10:45 AM
Okay a little update, I put the stock OEM back on and took of the stunk2 tb from the stunk 2 manifold. now I'm having idle issues. Rpm is jumping up and down from 2500 rpm to 900 rpm. But when complete stop no idle motor is fine...
Old 03-29-2013, 06:57 AM
xile6's Avatar
New gaskets?
Check for a vac leak.
Old 03-29-2013, 08:21 AM
Originally Posted by xile6
New gaskets?
I check that too, spray some tb cleaner around it nothing happen..
Old 03-29-2013, 07:38 PM
Warm your car up, turn it off then unplug your idle air control valve sensor. Turn the car on and see if the idle drops. Don't drive it with the sensor unplugged. If that doesn't help plug the iacv sensor back in try the same thing with the TPS sensor. Let me know what happens.
Old 04-08-2013, 11:15 AM
Problem fix, I thought I reply long ago and I notices it wasn't reply. I'm sorry, the problem was the ((skunk 2 tb I change it back to a oem tb)) that I got laying around. It change the idle from 2000 to 900 rpm then I adjust the idle screw and put back the short ram intake, done. Thanks a whole bunch guys!!!
HondaCivicSE
05-30-2014 01:53 PM
RotaryPWR
10
08-17-2009 08:32 AM
marinse
12-09-2007 12:28 PM
Interlude99
08-27-2004 01:28 AM
WRTEG
03-28-2004 06:32 AM
Quick Reply: 00 civic ex high rpm 2000 rpm.
