00 civic dx throwin' codes like dollaz - p0300 p0301 p0302 p0303 p0304 p1399
Old 10-07-2010, 06:23 AM
  #26
sanchg3's Avatar
Default Re: 00 civic dx throwin' codes like dollaz - p0300 p0301 p0302 p0303 p0304 p1399
Ok check my icm and my coil and they pass any suggestions what to do next
Old 10-07-2010, 06:28 AM
  #27
Former User's Avatar
Did you replace the Bosch spark plugs with NGK?
Old 10-07-2010, 07:34 AM
  #28
sanchg3's Avatar
Yes I did
Old 10-07-2010, 01:24 PM
  #29
sanchg3's Avatar
engine is hard to star it takes about 20 trys or more, sometimes when it starts the engine sputters now help
Old 10-07-2010, 02:35 PM
  #30
Technical Hero
HondaPartsHero's Avatar
What do the plugs look like? Are they wet will fuel? Really white?
Old 10-09-2010, 07:02 AM
  #31
sanchg3's Avatar
Sorry been working a lot but I can check them today what dies that mean if they r really white
Old 10-09-2010, 07:33 AM
  #32
Jimster480's Avatar
really white is either burning coolant or running super lean.
Old 10-09-2010, 09:06 AM
  #33
JdmCoupe91's Avatar
Wow... A misfire in every cylinder and then some...
Unheard of xD
Good luck man I wish I could help.
Old 10-07-2013, 08:20 PM
  #34
Borincano's Avatar
Check your voltage regulator on your alternator, make sure you have all accesories on when you test it. Thats what I went through, Alt tested good when everything was off, but once u turn lights, ac, stereo and etc at the same time, the alt failed. If not then check your pcm,=ignition control module also called powertrain control module.
Old 10-07-2013, 08:22 PM
  #35
Borincano's Avatar
codes 1399 302 300 301 voltage regulator can be the cause
Old 03-21-2015, 01:25 AM
  #36
DOMAN!EJ8's Avatar
would putting the wrong fuel like e85 cause a misfire? p0301 p1399
MugenRNR
Northern California (Sales)
12-17-2018 02:40 PM
MrStudioCans
08-30-2016 03:08 PM
Himynameismatty
18
11-21-2015 04:43 PM
Quick Reply: 00 civic dx throwin' codes like dollaz - p0300 p0301 p0302 p0303 p0304 p1399
