[FAQ] Power Windows, locks, Mirrors into EG Civic
#30
Location: Why so you can pretend like youre interested, FL/OK
Re: (*****StEr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by methos713 »</TD></TR><TR><TD CLASS="quote">went to the junkyard today...noticed that all the power window wires/assembly was gone from the 5th gen civics w/ power windows. So now, I want to know if I could use the wires or the powerwindow motors from the integras.
Modified by methos713 at 7:21 AM 3/13/2005</TD></TR></TABLE>
This was no doubt answered, but I would bet you would be able to use the door harness from the 1994-97 Integra with power windows. Everything with exception to the power door lock actuator to the power window motor. But the wiring I would say is a 99% go for being the same perhaps just different colors if anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by *****StEr »</TD></TR><TR><TD CLASS="quote">bump diggity ump</TD></TR></TABLE>
It's in the FAQs.
It's in the FAQs.
#31
Re: (INVALID)
Ahhh! Back from the dead I see. I did just the power mirrors and power door locks. I didn't really want the power windows. This write up did help though. for a old but helpfull DIY.
#34
Re: (Cuong-nutz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cuong-nutz »</TD></TR><TR><TD CLASS="quote">Those pictures are fumondo huge when you click the link! </TD></TR></TABLE>
but when i try to print it out it is either hella big or very small and blurry.
#35
Re: (*****StEr)
but when i try to print it out it is either hella big or very small and blurry. </TD></TR></TABLE>
That's on your end. Try Print Preview before you print out. It wouldn't change on this end since the links aren't being altered and your printer is only seeing the page your selecting. If you want huge pics. Just right click and open the picture in a new window then just individually print those ones off.
#36
Re: [HOW-TO] Power Windows, Locks, Mirrors into EG Civic (Cuong-nutz)
i was tryint o convert my car into power windows and lock's
but i'm having one problem....do i need to change the indash harness ???
or i can keep the OEM harness ???
please let me know
please let me know
#37
Re: [HOW-TO] Power Windows, Locks, Mirrors into EG Civic (99b16hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99b16hatch »</TD></TR><TR><TD CLASS="quote">what all do i need to down this swap in a 99 dx hatch and is it the same steps</TD></TR></TABLE>
x2 for a 99 CX HB if that makes any difference....
#38
I did this swap and I used all the factory wires. I'am having trouble with the dome light, doesn't work when driver's door is open. I noticed a set of wires that seemed not to have a home. ( in the picture I think it's the one in the yellow circle with the grey end ) I looked around and found the wire connection for the dome light. The plug ends are the same and I was wondering if this is the source of my problem. I pluged in the new wire and no dome at all. Any ideas?
I already checked the connections and contacts of the driver side switch and it seemed okay. Can somebody with a helms help. I looked in my chilton's and didn't see it in any of the diagrams. Any ideas would be helpful. Thanks.
#40
I was wondering, what do I need to buy if I only want to do only a power door conversion into my 2000 DX Hatch?
#41
Re: (Bond)
hey this may be old but
i have a 1992 eg4 civic hatch and what part should i use to get the drivers locking motor from?
please help
please help
#43
wire ????
hey i got a 94 civic dx hatch and i got my hands on a pair of 95 civic ex doors every things is still on them such as power windows, power locks, but i was wondering what is the item # of the wire harnest that is behind the dash and connect to the doors. so if any one could fine out for me that would be great thanks you!
#44
Re: wire ???? (skykeeper)
ok i know this is old but i gotta 94 hatch and a ex coupe that i bought for parts stripped and sent to the yard, i cut the inside harness as least as possible from the coupe. like i got the WHOLE thing. but i cant figure out how to get it in my hatch. i finished putting the lock motors and window motor/regulator in
but is it just plug and play? like is the hatch PREwired for windows and locks? meaning can i just run the harness thru the door, thru the body, and plug it into the harness i got from the coupe and just plug that in? or is it easier to just cut the harness and splice? and if so, are the 2 harnesses the same colors so i can just match colors from the 2??..but that would mean the hatch is prewired...? cuz if not how else is there any power going to the passenger side??
help, cuz the window is all the way up and the glass isnt on... i gotta get the power to it to lower the regulator so i can install the window... and its ******* COLD..
#45
Re: wire ???? (HatchEh2)
The hatch is not prewired. You'll have to run the harness you got from the EX onto your hatch. From there everything should plug up unto the fuse box. I don't know if you cut the passenger body to door harness. The colors are different as I said in the How-To.. The wiring diagram is your friend.
#47
Re: [HOW-TO] Power Windows, Locks, Mirrors into EG Civic (b16hatche)
Are the regulators from an Si (manual) the same as an EX coupe's (power)? Looking down the doors the regulators look the same. The only thing different is the hatch has a manual crank attached to the regulator, while the EX coupe's power window motor is attached ot the regulator.
Just curious as the writeup said to use the EX regulator. Maybe there's some small difference between an Si and EX regulator that I can't see.
#49
i hate to bring this thread back from the dead (sorta) but i just found it. i got a wrecked Sol with power locks and mirrors, the one i drive does not have that, can i use this writeup for my 1993 Del Sol too or are a couple things different?
