1997 CIVIC BUCKS/CHUGS WHILE ACCELERATING. PLEASE HELP!!
Old 04-22-2011, 04:46 AM
swade0103x's Avatar
Default 1997 CIVIC BUCKS/CHUGS WHILE ACCELERATING. PLEASE HELP!!
Recently got a new distributor and when I got the car back I noticed about a week later that the car started bucking while accelerating, especially 2nd and third gear. No smoke or smell. Does anyone have any idea what this could be? Did the mechanic put the distributor back wrong or can it be a wire plug issue? Thanks to all that can help.
Old 04-22-2011, 04:50 AM
The Grumpiest
grumblemarc's Avatar
Default Re: 1997 CIVIC BUCKS/CHUGS WHILE ACCELERATING. PLEASE HELP!!
You posted this yesterday.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/1997-civic-bucks-while-accelerating-please-help-2926204/
Old 04-22-2011, 05:24 AM
RoLLn98Ej6's Avatar
mine did that too a while back when i changed my distributor's coil pack... to correct the problem i loosened all three bolts that hold the dizzy, twisted it as far right(clockwise) until there is only space on the left side of the bolt & re-tighten them. that fixed my issue. you should try that maybe it will work for you too.
Old 04-22-2011, 07:39 AM
swade0103x's Avatar
rolln98 thank for input. I just need clarification... u said turn clockwise till there is only room on left side of screw but doing the puts all space on right side. should I go clock wise or countercclock wise? It is in the center now. thanks
Old 04-22-2011, 09:38 AM
swade0103x's Avatar
Icon2 Re: 1997 CIVIC BUCKS/CHUGS WHILE ACCELERATING. PLEASE HELP!!
question about the distributor. If you replace it does it matter if the wires from the spark plugs to the connections on the distributor go to any connection on the distributor or does each spark plug/cylinder have a specific connection on the distributor?
Old 04-22-2011, 03:57 PM
RoLLn98Ej6's Avatar
you're so right man, my bad well i mixed up but turn it which ever way just so that the space is to the left side of the bolt, which incase you would be right to turn counterclockwise... & yes each sparkplug/cylinder has a specific connection to the dizzy.
Old 04-22-2011, 04:04 PM
RoLLn98Ej6's Avatar
here's an article on the order:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/d16-distributor-cap-head-spark-plug-wire-order-%2A%2Aplease-help-asap%2A%2A-446102/
Old 04-23-2011, 04:50 AM
swade0103x's Avatar
Thanks ROLLn you have been alot of help to a broke novice. If anyone knows if this is the true order for my distributor connections please confirm here because the posts show two diff. configs.
******2
**4***1
******3
motor: 4321
thanks again
Old 04-23-2011, 07:12 AM
frankenghia's Avatar
I personally wouldnt just turn my dizzy all the way to one side. You need to get a timing light and adjust the timing correctly. You could hurt your motor running fully advanced or fully retarded. Not to mention the gas mileage and possible detonation.....
Old 04-23-2011, 07:15 AM
I believe its 1-3-4-2....firing order.....
Old 03-22-2024, 07:26 PM
bclow's Avatar
swade0103x is a pathetic MORON
Old 03-23-2024, 08:51 AM
spAdam's Avatar
A+ first post, broseph. You must get tired of winning the internet so hard.
Fezzie
08-01-2006 12:55 PM
Quick Reply: 1997 CIVIC BUCKS/CHUGS WHILE ACCELERATING. PLEASE HELP!!
