1997 CIVIC BUCKS/CHUGS WHILE ACCELERATING. PLEASE HELP!!
Recently got a new distributor and when I got the car back I noticed about a week later that the car started bucking while accelerating, especially 2nd and third gear. No smoke or smell. Does anyone have any idea what this could be? Did the mechanic put the distributor back wrong or can it be a wire plug issue? Thanks to all that can help.
Re: 1997 CIVIC BUCKS/CHUGS WHILE ACCELERATING. PLEASE HELP!!
rolln98 thank for input. I just need clarification... u said turn clockwise till there is only room on left side of screw but doing the puts all space on right side. should I go clock wise or countercclock wise? It is in the center now. thanks
question about the distributor. If you replace it does it matter if the wires from the spark plugs to the connections on the distributor go to any connection on the distributor or does each spark plug/cylinder have a specific connection on the distributor?
you're so right man, my bad well i mixed up but turn it which ever way just so that the space is to the left side of the bolt, which incase you would be right to turn counterclockwise... & yes each sparkplug/cylinder has a specific connection to the dizzy.
Thanks ROLLn you have been alot of help to a broke novice. If anyone knows if this is the true order for my distributor connections please confirm here because the posts show two diff. configs.
******2
**4***1
******3
motor: 4321
thanks again
******2
**4***1
******3
motor: 4321
thanks again
I personally wouldnt just turn my dizzy all the way to one side. You need to get a timing light and adjust the timing correctly. You could hurt your motor running fully advanced or fully retarded. Not to mention the gas mileage and possible detonation.....
1997, accelerate, accelerating, bucking, bucks, cap, chugs, civic, distributor, engine, gas, giving, honda, jumps, periodically, trouble
