*~*SWAPPIN MOTOR QUESTIONS??? HELPPPPPP*~*
Dropin B16 Out Si Need To Kno Wht Size
Sockets To Use On The Motor Mounts And Torque
Mounts And Also Size To Take Out The Axles.......
Lett Me Knooooo
Lett Me Knooooo
Re: *~*SWAPPIN MOTOR QUESTIONS??? HELPPPPPP*~* (EG*5*CIVIC)
I am not trying to be a A-hole, but if you don't know what size of socket to use I really find it hard to believe you'll be able to swap an engine
Get together with someone that has done it before, and learn from that person
driver, passenger, torque mounts...........14mm or 9/16 deep sockets, 1/2 drive
back mount (fire wall)...... 17mm
L - bracket bolts to transmission (fire wall)..........19mm
good luck!!
The mount besides the cams needs a deep 17mm socket, the side one I believe 14-15mm The rest are just a bunch of 12mm-14mm and 17mm every now and then for the long ones. When I bought my toolbox the deep sockets only went from 10-15mm so I bought the extra 17mm, and the 32mm and thats it.
Buy a nice long breaker bar . . .
* Off topic suggestion*
Proper English will help you get more responses on your posts. Take advantage of the spellchecker on this site.
Good Luck!
Good Luck!
Re: *~*SWAPPIN MOTOR QUESTIONS??? HELPPPPPP*~* (Juan_Mitosis)
I don't know why no one uses the search or the faq at the top of the forum... as said before.. You probably shouldn't be swapping if you can't find out on your own.
Re: *~*SWAPPIN MOTOR QUESTIONS??? HELPPPPPP*~* (riceburnerryan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburnerryan »</TD></TR><TR><TD CLASS="quote">I don't know why no one uses the search or the faq at the top of the forum... as said before.. You probably shouldn't be swapping if you can't find out on your own.</TD></TR></TABLE>
90Rexx
03-27-2009 03:54 PM
