***The speedometer on my 93 civic EX works and stops working, then works again.****
I borrowed a friend cluster and it works fine, it is my cluster itself that is not working. It is like something is loosing contact or something. Things to clean?? Please help!!!
Re: ***The speedometer on my 93 civic EX works and stops working, then works again.**** (galaxykid70
hehe, if i tap mine at idle with my figer it will jump up 5 mph at a time, all the way to 60 mph, and it will stick there, until i turn the car off and tap it again, it goes back down to 0 and unsticks, CRAZY CLUSTERS!!!!!
i know the accord like the 94-97 the gague clusters on the odometer sticks and you can usually just tap it alittle bit. What happens is that the plastic on the needed or the coil that the needle there is a coilwind on the back part of the needle I think from the heat it melts. But it hitting doesn't do anything and your talking about lights etc.. electrical. I would check connector pin fit. Or just simply pull the conector out and re-fit it. Might not be in 100 percent. 99 percent most electrical problems are terminal pin fit.
Re: (crx1.8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx1.8 »</TD></TR><TR><TD CLASS="quote">i know the accord like the 94-97 the gague clusters on the odometer sticks and you can usually just tap it alittle bit. What happens is that the plastic on the needed or the coil that the needle there is a coilwind on the back part of the needle I think from the heat it melts. But it hitting doesn't do anything and your talking about lights etc.. electrical. I would check connector pin fit. Or just simply pull the conector out and re-fit it. Might not be in 100 percent. 99 percent most electrical problems are terminal pin fit. </TD></TR></TABLE>
yeah but the thing is even when I would go 80 mph, the cluster would work, stop working, then work again in a matter of 2 seconds, so I don't think it is stuck, I think it is loosing contact somewhere.
Re: (HTn00b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HTn00b »</TD></TR><TR><TD CLASS="quote">yeah but the thing is even when I would go 80 mph, the cluster would work, stop working, then work again in a matter of 2 seconds, so I don't think it is stuck, I think it is loosing contact somewhere.</TD></TR></TABLE>
bump
bump
Re: (SoHc94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoHc94 »</TD></TR><TR><TD CLASS="quote">check yur sensor make sure its not loose or anything .</TD></TR></TABLE>
where it that located?
Re: ***The speedometer on my 93 civic EX works and stops working, then works again.**** (HTn00b)
https://honda-tech.com/zerothread/382416
scroll down a lil bit. it will show u i kant get the picture to werk.
thats gonna be behind yur starter pretty much. on yyur tranny.
Modified by SoHc94 at 9:37 PM 8/23/2006
Re: (pprreelluuddee)
and I thought I was the only one with this problem, I have a 97 dx with a b16 and it does the same thing, also my cousin had a 92 cx hatch with a type r motor and it started doing it to the guy he sold it to so if anyone has had this problem and fixed it I would love to know how, otherwise anyone with an SI cluster that they would like to sell I'll take it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pprreelluuddee »</TD></TR><TR><TD CLASS="quote">bump would also like to know.
rpm , gas , temp works fine.
however the speed mph odometer and the trip and the miles. stop on and off?</TD></TR></TABLE>
yes everything works perfect except the speedometer.
Re: ***The speedometer on my 93 civic EX works and stops working, then works again.**** (SoHc94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoHc94 »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread/382416
Modified by SoHc94 at 9:37 PM 8/23/2006</TD></TR></TABLE>
Ya mean these guys?
It's the black thing with the bolt and the wire... :-P
EDIT:
Oh, incase u dunno what that is...that's the top of the tranny...like looking down on it from above O.o
Ya mean these guys?
EDIT:
Re: ***The speedometer on my 93 civic EX works and stops working, then works again.**** (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">Ya mean these guys?
EDIT:
Oh, incase u dunno what that is...that's the top of the tranny...like looking down on it from above O.o</TD></TR></TABLE>
Yeah I thought that was my problem so I unplugged that and cleaned it and the cluster did the same thing, then I put another cluster on and it worked perfectly so that means it is the cluster.
EDIT:
i had the same problem in my 92 hatch. i just took the cluster apart and took the speedo assembly out and switched it with another one. and it works fine till this day. if u do plan on doing this just be carefull with the needle when taking it off.
Re: ***The speedometer on my 93 civic EX works and stops working, then works again.**** (slamedcivic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slamedcivic »</TD></TR><TR><TD CLASS="quote">i had the same problem in my 92 hatch. i just took the cluster apart and took the speedo assembly out and switched it with another one. and it works fine till this day. if u do plan on doing this just be carefull with the needle when taking it off. </TD></TR></TABLE>
That's what I did too when my speedo was going out. I bought a VX cluster from a junkyard and the speedo started going out so I replaced it with the speedo from my DX cluster I kept laying around.
You can order the speedo itself from the dealer and the VSS too but knowing dealer prices they'll probably charge a lot more than what you think.
Modified by eetmaishiet at 9:28 AM 8/24/2006
bump for the picture above. are you referring to a VSS vehicle speed sensor. If so, I honestly dont' think tha'ts the problem.. it has somehthign to do with the tach. a loose wire I might say..
you can buy a cluster and swap it out, but that'll cost more. try asking honda. maybe it's cheap. but either way, swapping out the whole center speedo or the chip will fix it.
Re: (lv6l)
IM going to swap the motherboard off a cheap cluster, would a automatic cluster motherboard be the same as a manual??
Re: (Chumbas_EG9)
Same kinda problem here. Except I'm on my third cluster.
1st one - speedo needle would jump periodically and the odometer would stop counting.
2nd one - speedo needle would jump periodically and sometimes when I hit the turn signals.
3rd one - when I start the car, the speedo needle will jump up to 60 mph, or 110 mph, and so on...
Have no idea where to start fixing this thing.
