"WRX" Sound
"WRX" Sound
Hey, i have a 99 si with a swapped B16A. I'm only 16 and it's my first car. I've searched around for a while but havent found anything yet. It sounds almost like a wrx. I've read that this sound is usually a symptom of a burnt valve(s), or if it isn't runnin on all cylinders. I have had the valves checked, all good as gold. Good compression all across also. The car still pulls good and there's been no power loss. Will give a little puff of smoke at vtec, but that's it. Are there any other reasons that it could sound like this?
Re: "WRX" Sound (95sloweg)
I checked that already, they're all in their places....I had distributor cap and rotor button replaced also(forgot to mention), didnt help. I'm new to it all...and lost.
Re: "WRX" Sound (oneludesol)
The car was like this when it was bought (May). It does have a megan racing header ( with full tsudo N1 exhaust)
Sorry, but what do you mean by that?(I'm aware that I'm only allowed 5 posts) What part of the header is the runner.Never heard of that. Guess we learn something new everyday. Thanks for the help so far guys
GDD's Dr. Phil?
Re: "WRX" Sound (NSB16A)
I think there is a crack in one of the runners of your header... take the header off, and look at it very carefully all over.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NSB16A »</TD></TR><TR><TD CLASS="quote">Sorry, but what do you mean by that? Thanks for the help so far guys </TD></TR></TABLE>
You can only post 5 times a day since youre in a trial membership for about a week. You can't post anymore within 24 hours but you can still edit your posts to type something in!
Re: (Hardedge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hardedge »</TD></TR><TR><TD CLASS="quote">Just out of curiosity, what do you mean when you say you have a '99 Si with a "swapped B16A"? Was the motor simply replaced for some reason?</TD></TR></TABLE>
up here in canada the si model has the d16y8 or z6, unlike you guys in the states.
if its a 2 piece header... check to see if there is an exhaust leak on the header...
i have a 2 piece kamikaze header and when the gasket blew the one that is between the 3 bolts on the header my car sounded like a WRX too...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikey82 »</TD></TR><TR><TD CLASS="quote">
up here in canada the si model has the d16y8 or z6, unlike you guys in the states.</TD></TR></TABLE>
Oh, I didn't notice that he's in Canada.
Re: (Hardedge)
pull all of your injector plugs off 1 at a time and if the sound doesnt change at all when you pull 1 off or another off thatll be your prob. i had the same exact sound when i rewired my injector plugs to in stall new injectors. was there any wiring done on the car in order to facilitate the swap?
Re: (Garage oNe mOnKeY)
i agree check you injector plugs more than likley one isnt all the way on there... other things could be a bad spark plug....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NSB16A »</TD></TR><TR><TD CLASS="quote">Hey, i have a 99 si with a swapped B16A. I'm only 16 and it's my first car. I've searched around for a while but havent found anything yet. It sounds almost like a wrx. I've read that this sound is usually a symptom of a burnt valve(s), or if it isn't runnin on all cylinders. I have had the valves checked, all good as gold. Good compression all across also. The car still pulls good and there's been no power loss. Will give a little puff of smoke at vtec, but that's it. Are there any other reasons that it could sound like this? </TD></TR></TABLE>
I have a friend in New Glasgow with a 91 hatch with a b16 swap in it. It sounds like a subaru as well. Car runs perfect (14.7 @ 93mph). I think his is because of the 4-1 header on it. No need to fix it if it isnt broke IMO.
Re: "WRX" Sound (Slothy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slothy »</TD></TR><TR><TD CLASS="quote">
I have a friend in New Glasgow with a 91 hatch with a b16 swap in it. It sounds like a subaru as well. Car runs perfect (14.7 @ 93mph). I think his is because of the 4-1 header on it. No need to fix it if it isnt broke IMO.</TD></TR></TABLE>
x2
I have a jdm b18c-R swap with megan 4-1 headers, test pipe, and full 2.5 megan "drift spec" exhaust. And it sounds like a WRX, runs perfect..
x2
