"rear washer trick" for the camber kit!?
Old 04-08-2006, 03:04 PM
KMk51188's Avatar
Default "rear washer trick" for the camber kit!?
can some one explain to me how to do the "rear washer trick" for the camber kit on a eg i have ingalls camberss i bout the screws n washers from home depot but now i need how how to do the trick please help some1
Old 04-08-2006, 03:08 PM
Unceasing Measure
Archidictus's Avatar
Default Re: "rear washer trick" for the camber kit!? (KMk51188)
Search dumbass, this is covered 9 times a day. It's also on the Omnipower website.
john666's Avatar
the 2 i believe its 12s or 14s on the back top.(u see it when tire is removed) unscrew those. put washers and the longer screws thats it
Old 04-16-2006, 09:31 PM
integrax97's Avatar
Default Re: "rear washer trick" for the camber kit!? (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Search dumbass, this is covered 9 times a day. It's also on the Omnipower website.</TD></TR></TABLE>
nice, glad to see these fools tryin to help you and callin you names, stay classy
Old 04-16-2006, 09:45 PM
Turbo_y8's Avatar
Default Re: "rear washer trick" for the camber kit!? (austinxtreme512)
take your rear wheels off, locate the upper control arm. It connects to the frame with two bolt. That the bolts out and get slightly longer and by slightly like maybe a 1/4" and some washers. Washer go between the frame upper control arm. done
Old 04-16-2006, 09:46 PM
Voyage34's Avatar
Default Re: "rear washer trick" for the camber kit!? (tuck'd98)
https://honda-tech.com/zerothread?id=1465602
My JDM EJ8
03-16-2008 12:24 PM
brianmcivics
Suspension & Brakes
02-06-2008 07:56 AM
YAH YAH
Suspension & Brakes
05-10-2007 05:16 PM
jromulo
Suspension & Brakes
07-30-2005 09:27 AM
Denny
12-15-2002 07:22 PM
Quick Reply: "rear washer trick" for the camber kit!?
