tl wheels on an 06 civic sedan
i found some 06 tl wheels 17X8 and wanted to know if anyone thinks they will stick out past the body?? let me know what yoy all think
Re: tl wheels on an 06 civic sedan
bump the wheels specs are 17" x 8" 45mm offset 5 x 4.5 (114.3mm) bolt pattern
someone let me know whats up (will they stick out, rub, or just look like ****) cause i have till later on today to decide if i want them or not... thanks
Re: tl wheels on an 06 civic sedan (Phrost)
People have had rubbing issues with the calipers of non-Si models when mounting Si rims which are 17 x 7 with 45 mm offset. You probably should test them on the car before buying them.
Re: tl wheels on an 06 civic sedan (dontbother)
ill probably do that but i hope that they fit good cause i really like the rims and think they would good on the sedan
they SHOULD fit....
and i'll tell you why...
Dontbothertim has TSX wheels on his Si....
I had TL wheels on my TSX.....
neither with issues
SO.... you should be ok.......i think
neither with issues
Re: tl wheels on an 06 civic sedan (Type X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type X »</TD></TR><TR><TD CLASS="quote">they SHOULD fit....
neither with issues
SO.... you should be ok.......i think </TD></TR></TABLE>.
next time we are working on your Si, we can take my TL rims and see if they fit on your car
neither with issues
Re: tl wheels on an 06 civic sedan (rbf351)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rbf351 »</TD></TR><TR><TD CLASS="quote">.
next time we are working on your Si, we can take my TL rims and see if they fit on your car</TD></TR></TABLE>
haha i thought about that BUT civic ex is different than the Si
the si wheels almost rub on the EX where they have alot more clearance on the si
but if u wanna...
but if u wanna...
Check using this: http://www.1010tires.com/WheelOffsetCalculator.asp
It will tell you how much more it will stick out/in and then you can check on your car and see if that's ok.
AllMotorRandy
11
07-09-2008 09:14 PM
