Stuck:Car won't start, honda civic auto 2008 1.8
Hi guys,I was going on the road and car sudden stopped ( I-Shift sign came up mean yellow COG with danger sign in it ). Then after it won't start or change gears because it was not on neutral so i could not start. After a while managed to bring it on neutral by removing battery terminals for a while. When i started then it went stuck again on 2nd gear and it wont let me change gear. so i kept driving till got home keeping it same gear (as cant change gears ). I made car neutral someway few times then it starts fine. And it drove too but during drive, suddenly car wont change gear then it drives on same gear till turn off. but it also become slow on going uphill even on second gear. Now car don't start again, cos its not neutral and it wont let me change the gears again.
I called RAC man and it run through some test and gave me these result.
Comments Suspected Diagnosis –
tcm faulty
Diagnostic Codes RAC DIAGNOSTIC SYSTEM
System Type: GEARBOX
Name: GEARBOX - AUTOMAT / SEQUENTIAL GEARBOX
DTC: P0919,Gear Shift Position Control Error
DTC: P19E6,Clutch temperature to high (Over 300 °C (572F ))
DTC: P19FF,Clutch friction coefficient learning value out of range
DTC: P0562,TCM Power Relay Sense Circuit Low
DTC: U1261,Lost Communication With Anti-Lock Brake System (ABS) Control Module
DTC: U1403,CAN TCM/ABS Circuit Malfunction
DTC: 0810,unknown
System Type: BRAKES Name: ABS/TCS - DIAGNOSE
DTC: 17-1,Rear left wheel speed sensor open circuit
System Type: AC SYSTEM Name: CLIMATE CONTROL - DIAGNOSE
DTC: B1240,A problem in the mode control linkage, door or motor
DTC: B1235,Air mix damper position sensor circuit(Driver side)
DTC: B2991,Climate control unit lost communication with audio system
I am really stuck and dont have much budget. This is my first auto car so dont know much. Just found this forum that may find any solution. Hope to find someone with expertise in this field.
tcm faulty
DTC: 0810,unknown
White92eg
10-09-2010 01:48 PM
