Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
JDM Type-R valve cover installed...
Old 03-24-2007, 03:31 PM
blue rocket's Avatar
Default JDM Type-R valve cover installed...
Ok, first i'm going to touch on a few things, since i searched and searched before i bought my valve cover....but never found an answer to:
1 - There are no issues with putting the JDM Type R Valve cover on, except...there are no holes for the wires and such to the right of the valve cover...this honestly is no issue...i used a zip tie and a little rubber tape to make sure it sat securely and didnt rub against the valve cover.
2 - The breather tube on the JDM valve cover is wider than stock, you cannot reuse the stock clamp, but the hose will fit over it.
3 - I had a pain in the *** time getting the longer screws out on the stock spark plug cover...i ended up intentionally breaking the stock spark plug cover to get the bolts out so i could then get the nuts off - if you replace the spark plug cover you'll know what i'm talking about! The pic below shows what screws i'm talking about! (If you don't want to break your spark plug cover...the nuts do actually come apart from the bolt, i just wasnt able to get a strong enough grip on the bolt, if you have a vice you should be fine!)
Other than that...i bought a new valve cover gasket, didnt use any type of sealant, it's not neccessary. Take your time removing the plastic cowl around the windshield wipers...it's not difficult to remove, but if you force it off you can break things. Total time of installation ~1.5 hours.
Here are a few pics!
Oohhh, thanks fedex!
Mmmm, JDM newspaper...
Before:
After:
Sorry for the bad lighting!
For anyone not sure how to remove the valve cover...it's pretty straight forward, thanks to BCJ fo the easy to follow write up!
http://www.8thcivic.com/forums...asket
Modified by blue rocket at 5:43 PM 3/27/2007
Old 03-24-2007, 03:38 PM
reaper702's Avatar
wow that looks sooo good and tempting..
Old 03-24-2007, 03:45 PM
haby red fg2's Avatar
looks good just needs the jdm dipstick
Old 03-24-2007, 03:51 PM
vinni's Avatar
Default Re: (haby red fg2)
nice.
Old 03-24-2007, 03:52 PM
IT GUY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haby red fg2 &raquo;</TD></TR><TR><TD CLASS="quote">looks good just needs the jdm dipstick</TD></TR></TABLE>
what he said.. US dipstick won't read right with the JDM valve cover
looks great though
Old 03-24-2007, 03:58 PM
yeah...if it read correctly it would be on there...
Old 03-24-2007, 04:13 PM
japspecjohn's Avatar
Default Re: (IT GUY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT GUY &raquo;</TD></TR><TR><TD CLASS="quote">what he said.. US dipstick won't read right with the JDM valve cover
looks great though </TD></TR></TABLE>
i thought the jdm dip sticks didnt read right?
Old 03-24-2007, 04:37 PM
Default Re: (blue rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue rocket &raquo;</TD></TR><TR><TD CLASS="quote">yeah...if it read correctly it would be on there...</TD></TR></TABLE>
wow are you serious it doesn't read correctly why is that
Old 03-24-2007, 04:40 PM
wow are you serious it doesn't read correctly why is that </TD></TR></TABLE>
it's shorter.
Old 03-24-2007, 09:13 PM
95turbodteg's Avatar
i love that in the jdm newspaper there is a big *** pic of marilyn manson. looks good mang!
Old 03-25-2007, 11:43 AM
mInI m3 Hondeezy's Avatar
Default Re: JDM Type-R valve cover installed... (blue rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue rocket &raquo;</TD></TR><TR><TD CLASS="quote">Mmmm, JDM newspaper...
Thats the most JDM ived seen.
Old 03-25-2007, 11:56 AM
TypeRBoy's Avatar
OH MAN..that's beautiful.
You need to lose the i-VTEC silver cover and expose the full beauty of that red wrinkle finish. When I put the valve cover on my previous RSX-S, I left it off to show the full glory. Just my .02, if you like it, leave it the way it is.
Old 03-25-2007, 01:11 PM
Nighthawk R18's Avatar
i like the look better without the grey iVTEC cover.
looks good nonetheless
Old 03-25-2007, 01:49 PM
dt98gsr's Avatar
Default Re: JDM Type-R valve cover installed... (Nighthawk R18)
Looks much better, I just picked my GGM Si up Saturday morning, I was thinking about making this one of my first mods, as you already know I'm sure the engine compartment is pretty cramped, did that cause any issues during the install? Just curious.
Old 03-25-2007, 03:25 PM
Default Re: JDM Type-R valve cover installed... (dt98gsr)
The small engine compartment wasn't an issue, once you remove the shroud around the wipers and the heat shield below that...
Old 03-25-2007, 05:36 PM
xmx250's Avatar
nice
Old 03-26-2007, 08:50 AM
IT GUY's Avatar
I thought it only read incorrectly because of the height of the JDM valve cover... which would mean that the US dipstick reads wrong now, right?
Old 03-26-2007, 08:52 AM
I thought it only read incorrectly because of the height of the JDM valve cover... which would mean that the US dipstick reads wrong now, right?</TD></TR></TABLE>
lol, hell, i'm confused now! Anyone have an accurate answer to this?
Old 03-26-2007, 09:20 AM
SYTFU Tommy.'s Avatar
thats a chinese news paper thus not jdm at all
Old 03-26-2007, 09:43 AM
IT GUY's Avatar
lol, hell, i'm confused now! Anyone have an accurate answer to this?</TD></TR></TABLE>
Looks great though! Did the RSX's have a similar issue with the dipstick?
Old 03-26-2007, 12:34 PM
COMplex.'s Avatar
I'll check when I get home to be sure, but I remember holding both dipsticks side by side and they were the same.
Again, I'll confirm later, but I'm 99% sure.
Old 03-26-2007, 08:17 PM
IT GUY's Avatar
Default Re: (SYTFU Tommy.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SYTFU Tommy. &raquo;</TD></TR><TR><TD CLASS="quote">thats a chinese news paper thus not jdm at all</TD></TR></TABLE>
might be published in chinese, but it has ads from phoenix arizona on it!
Old 03-27-2007, 01:03 AM
Mediademics's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT GUY &raquo;</TD></TR><TR><TD CLASS="quote">might be published in chinese, but it has ads from phoenix arizona on it!</TD></TR></TABLE>
I just called the 800# on the paper and it's for Samco Financial Services. You can't see the full name because of the fold in the paper.
The things I do when I am bored at work
Install looks good BTW.
Old 03-27-2007, 03:43 PM
poljana's Avatar
Default Re: (Mediademics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mediademics &raquo;</TD></TR><TR><TD CLASS="quote">
Install looks good BTW. </TD></TR></TABLE>
Boredome at it's finest!!!
Old 03-27-2007, 04:56 PM
Default Re: (.COMplex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .COMplex &raquo;</TD></TR><TR><TD CLASS="quote">
Again, I'll confirm later, but I'm 99% sure. </TD></TR></TABLE>
u ever confirm?
Quick Reply: JDM Type-R valve cover installed...
