Improving the steering feel?
#26
Re: Improving the steering feel?
lol what does this have to do with steering feel? Are you a car enthusiast or just a SI humper? Try picking up a C&D mag and learn how professional journalist critique cars.....
#27
NO MERCY!
#28
Well it just compliments the cars build quality and it's ability to hide speed.
So since you are so in tune with how the "pros" critique cars, why don't you tell me. I'd love to know.
I actually have an old car and driver or road and track or motortrend, I don't remember which one it was but they were testing the mugen and they said the chasis could handle another 100hp and would benefit from a turbo which wasn't available in the Si obviously.
So I guess I learned well from a car magazine and put a sweet *** turbo on it that I'm sure you would love to drive but can't.....oh well for you....too bad too sad
uh oh somebody got a turbo...
#29
NO MERCY!
Well mr. jew jew bean, I actually don't like front wheel drive cars. I'm just making the best of my situation right now. I read mags all the time.
And on that day.....I....RICO.....will look down on you from the heavens above and I will chuckle just a little bit. And then you will know at that very moment.........KARMA IS A BITCH!
#30
Karma Shmarma....nah I'm a good dude. I got nothing to worry about!...That's ok if it does blow that's when it'll be time to build the motor and crank the boost to 20 or so and have 500 or 600whp
#31
NO MERCY!
#32
He knows where you live!
So what does this have to do with improving the steering feel again? Every thread you post in turns into a debate about your turbo that you cannot shut up about. It's almost as if you're trying to justify it to yourself in every thread you post in
To the OP, on the cheap side you're not going to have any "quick fixes" to improve the steering feel/feedback in the Civic. From what I noticed it is as you said accurate but not much feedback - one of those drive by wire drawbacks
Stiffer sways front/rear that keep the same ratio will just give you a stiffer chassis feel and keep you flatter but will not help your steering feedback. I am not sure why someone recommended reducing your rear sway for more understeer, the car seems fairly balanced as is.
#34
Who did that? I reread all of the replies and I didn't see where anyone recommended reducing the rear sway bar. I did recommend he swap out his front sway bar for a smaller LX/EX unit to increase oversteer.
#35
Steering feel is easy.
1. 18" wheels with 35-40 series tires.
2. Upgrade your suspension first. s2 Pro-C or something along those lines will work out great.
3. Upgrade the rear sway bar. Make sure you add the reinforcements to the mounts.
4. More negative camber.
5. Chassis braces.
5. Chassis braces.
#37
5. Chassis braces.
5. Chassis braces.
2. Where is it written that you have to get coilovers to improve your suspension. The main purpose for coilovers is to adjust corner weights.
3. or reducing the front sway bar which will accomplish the same effect without putting additional stress on the rear unit. A bonus is you might be able to accomplish this for free by trading.
4. more negative camber on the front tires, negative camber in the rear will cause under steer
5. This is a popular myth, the chassis on this vehicle is pretty rigid already. If one did put chassis bracing on this vehicle it would have a minimal effect if any.
#38
The truth is, our front shock towers mount very close to our A-pillar. There is nearly no need for a strut tower brace. As for the other chassis bracing, it's very effective. Simple things like properly tying your front left and right suspension together and to the chassis. Bolstering the lower rear brace, locking down that critical area between your rear seats and trunk and even gusset plates. Lots of flexing happens in these areas, reduce it to improve both feel and actual traction.
#39
As I have said before, there is absolutely no reason to plus size your wheels except to accommodate a larger brake package or use a tire that isn't available in the size you need. For racing, I'd actually step down to a 16 on this car with the brake upgrades I mentioned.
If you want to get specific on this one you are going to have to show overall ride hide of the wheel tire combo and the weights of the tires.
All the coilovers available for the FA/FG have their rebound and compression adjustment in 1 ****, unless the user is swinging and can afford Motons or wants to roll the dice on a set of over priced D2's. I can accomplish everything a coilover user (except corner weighting) can and reduce my costs with good set of dampers and custom springs. Coil overs on the street become nearly useless once the user has decided on a ride height, which why a lot of user buy them for.
Something I'd like to add is a lot of hobbyists who I installed coilovers usually skip the $89.99 recommended alignment untill they come back to me to order a $300 correction kit once they see their tires are gone. On this vehicle the camber goes positive while the rear goes a little more nagative creating a precarious situation
Myth, are you kidding me? I guess you know more than every racing team out there. You heard it here guys, HART and CUSCO know nothing, don't bother bracing your car.
Are we talking about all out race cars and trailer queens or are we talking about street cars that race at an occasional event.
Much more effective parts to spend money on than over priced chassis bracing bling-bling. I don't follow million dollar race teams, I follow the guys that drive their cars to the track or tow them with their families mini van.
#40
Perhaps, but you are discounting the tire. Going with a lower profile tire can have diminishing effect, a tire that has little to no sidewall flex can break traction sooner causing a loss of control.
Coilovers are the easiest way to adjust ride height and corner weighting.
To even try to argue on the grounds of not changing out other hardware is a stretch, you are grasping at straws on that one. Attempting to make my comments look overly complicated when it serves you then overly simple is a sad way to argue a point. You seem a smart guy, don't stoop to that.
On a daily driven car, are you kidding me?
You really should start following million dollar race teams, it's where all the tech for cars comes from. That guy that pulls his car to the track with the family van, he's using million dollar race team tech, might be older but it originated in the same place. What you should of said was, you like old tech because new ideas scare you. Cutting edge stuff happens in race teams, shortly after that it's made available to the public at a deeply discounted price. They pay millions for research, we pay pennies on the dollar for the exact same thing.
#41
when i lowered my civic and increased the negative camber in the front i noticed that the steering wheel got heavier but i wouldn't say that it got more responsive; i still have trouble telling when the tires are about to slip. i always listen for the squealing from the tires .
#42
#44
Did you just pick a number for the negative camber or did you really research it? In the end our car will never have the ultra responsive wheel feel you get from some other cars. The absolute best way is to get to know the car, and just as importantly get to know the tires.
#45
I don't mean to thread jack,
but....
I was always under the impression that running larger diameter wheels will actually slow the vehicle? So how can running 19" have any beneficial effects?
Isn't there a correlation between wheel diameter and vehicle speed, positive and negative?
Somebody school me here.
but....
#46
but....
but....
#47
But if the wheel is lighter couldn't there be some positive benefits? If you switched from stokc SI wheels to mugen 18" which are 16.x lbs as opposed to the 20lbs the stock wheels weigh (assuming tires don't offset that) you could increase your performance could you not?
#48
#49
yeah, the 18" mugens are lighter than the stock 17's, but 17" mugens would be even lighter than the 18" . even though the 18's are lighter, the weight is farther from the center of the wheel, and the farther out the weight is the more force it takes to spin it. i don't know which wheel is better for performance between the 17" stock and 18" mugen, but i bet once you take the tire into account the stock 17" is better.
#50
