Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Gas Pedal Lag?
Old 10-09-2007, 09:55 PM
RNbuilt's Avatar
Default Gas Pedal Lag?
i find it difficult to heel toe in the new si sedan because of the gas delay.
is there a fix for this such as the hondata reflash?
Old 10-10-2007, 12:46 AM
blue2ksi's Avatar
Default Re: Gas Pedal Lag? (NAB18CR)
no there isn't any fix... just gonna have to get used to it... with enough practice in this car, heel-toe can be tackled.
Old 10-10-2007, 05:17 AM
exhaust_note's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAB18CR &raquo;</TD></TR><TR><TD CLASS="quote">i find it difficult to heel toe in the new si sedan because of the gas delay.
is there a fix for this such as the hondata reflash?</TD></TR></TABLE>
whats is this lag you speak of. its just in everyones heads. GM's have been TBW since 03. Now the new models come out and there complaining of lag, its been the same system for the past 5 years. Same applys here.
Old 10-10-2007, 05:56 AM
TypeRBoy's Avatar
Default Re: Gas Pedal Lag? (exhaust_note)
I have read these complaints as well and I have never had this happen in my 07 Si Sedan. I do have a slight rev hang, but even this has never been an issue for me while driving. I know the DBW makes it harder for the aftermarket to make parts, but it has never effected the drivability of the car for me.
Old 10-10-2007, 07:41 AM
RNbuilt's Avatar
Default Re: Gas Pedal Lag? (TypeRBoy)
i find it hard since im used to the slightest tap and the motor revs. i drove my friends si and the delay sucks when i tried heeltoeing it. driving it feels the same. i guess itll take some getting used to.
Old 10-10-2007, 08:24 AM
its all in your head
Old 10-10-2007, 08:36 AM
elohel's Avatar
Default Re: (exhaust_note)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exhaust_note &raquo;</TD></TR><TR><TD CLASS="quote">its all in your head</TD></TR></TABLE>
No, it's really not. Go ahead and test it - come to a rolling stop and then blip the throttle. You'll notice it take up to a few seconds or several attempts to make the motor rev up. This is just one example of a couple of scenarios when this happens.
Old 10-10-2007, 08:44 AM
RNbuilt's Avatar
so the honda reflash or hondata reflash does not fix this problem or make it minimal?
is the tsx the same way?
Old 10-10-2007, 09:47 AM
fandirabbani08's Avatar
Default Re: (NAB18CR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAB18CR &raquo;</TD></TR><TR><TD CLASS="quote">so the honda reflash or hondata reflash does not fix this problem or make it minimal?
is the tsx the same way?</TD></TR></TABLE>
supposedly hondata helps, i wouldnt know since i have an fg1. also, depending on your vin range, the dealer may be able to update your ecu with the latest version on HDS.
Old 10-10-2007, 05:04 PM
New User
fg2si!kid's Avatar
Default Re: (fandirabbani08)
i have no trubble busting some heel-toe in my 07 si iam sure youll get used to it
Old 10-10-2007, 07:59 PM
drkangel650's Avatar
I can't say as to the post above about it being new or not, however I can say that it is noticed. Maybe if you have owned newer vehicles it isn't.
My last vehicle was a 1994 Chevy s-10. I hit the gas, it made sound. My 07 EX is considerably "slower" to rev up. It bothers me that I can tell a time difference between my foot depressing the pedal and my eyes and ears seeing the tach and hearing the engine.
On the other hand, my 07 has warranty and under 195K so I let it slide. =D
Old 10-11-2007, 08:01 AM
Default Re: (elohel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elohel &raquo;</TD></TR><TR><TD CLASS="quote">
No, it's really not. Go ahead and test it - come to a rolling stop and then blip the throttle. You'll notice it take up to a few seconds or several attempts to make the motor rev up. This is just one example of a couple of scenarios when this happens. </TD></TR></TABLE>
come out on the clutch a little and it will rev. its a safety feature.
when the clutch is fully depressed it wont rev up. but if you come off the floor almost to engagment, it will rev like a normal cable setup. its all in the programing.
e DoGG 4 sHo
11
06-17-2008 10:29 PM
90babyblue
20
05-12-2008 06:22 PM
Chunkdaduce
04-28-2007 05:39 PM
xunkn0vvnx
03-30-2005 05:33 PM
Rick Solis
45
08-20-2004 10:33 AM
Quick Reply: Gas Pedal Lag?
