Clickin' N Knockin'
Clickin' N Knockin'
08 Civic EX Coupe Automatic, 50K, Certified Used Car from Honda dealer.
I have had this vehicle about 2 months and have noticed two noises that are aggravating and alarming. The aggravating noise sounds as if it is a lifter clicking....I hear it when I am at idle. It sounds like a light tapping and sometimes goes away. I can't hear it while moving.
The second noise...the alarming one....sounds almost as if it is a rod bearing or piston pin. On light and constant acceleration under a light load I can hear the noise. Could this be some emission or exhaust noise?
Anyway I am getting it back to the dealer next week and I wanted to get some opinions from you guys and guyettes. Thanks in advance.
Note: I'm driving my pickup until I find out what's up with the noise.
Re: Clickin' N Knockin'
Have you found anything out from hte dealer about the noise? I have a similar issue and I don't want to spend to much money fixing the car up and then have a spun rod bearing.
The sound could be from the timing belt tensioner. One of my mechanic buddies told me to pray soapy water on the belts for any belt noise. I put a long screw driver to hear where that rattling noise is from and I can't figure it out. I tried adjusting the valves but no change. The sound is more erratic and not harmonious with the motor. Is the piston pin noise a rattling noise?
kenskii
07-08-2014 08:33 PM
