2010 Honda Civic runs cold in winter
#26
Re: 2010 Honda Civic runs cold in winter
Great thread.
I signed up just to give my input since Im having the same issues as the OP.
I live in Winnipeg where temperatures this past week have gone below minus 30C (not including windchill). Im not an engineer and have no mechanical qualification but have been around hondas since I was a kid.
About the temp gauge dropping, there are a few things that are pretty apparent given the experience we are having with 2010 civic.
1) Front bumper is allowing more air flow that previous 8th and 7th gen civics. which leads me to believe the extra mesh for fog lights on the bottom front bumper maybe allowing extra air flow into the engine compartment.
2) the radiator for the 2010's and 09's might be larger than the previous 06-08 models.
Maybe they were designed for 2.4 liter or 2.0 liter engines as opposed to 1.8 ones.
3) If the radiator is too large then that will means that the car will probably never overheat in the summer when using an AC but that means on really cold days you'll have a mild to warm air being blown into the cabin.
To remedy this temperature gauge problem I rarely turn heater dial to max. In fact, I leave it mostly on the first 2-3 red marks.
#27
Re: 2010 Honda Civic runs cold in winter - not warming up - temp thermostat problem
My 2010 civic has a digital water temperature gauge. The gauge does not display numbers, rather it has a LCD bar graph. During the spring, summer and fall the gauge displays 9 bars when the engine is fully heated, which is just shy of the halfway mark on the gauge.
In temperatures below 32 degrees Fahrenheit, the gauge only rises to 4 to 7 bars, even when the car has been driven for over 15 minutes. An odd thing is, sometimes it will display a normal temperature of 9 bars, even on very cold days, say 25 degrees, but this is rare. The heater works OK, the air seems warm enough. It seems that if I turn heater off, that the temp will raise one or two bars.
Maybe these small engines just dont have enough mass to warm up in the winter?
Dealer says nothing is wrong with 2010 civic, but this does not seem right to me. Any ideas, thanks.
Heres the kicker, my old 2001 civic did the same thing in its older years, dealer said there was nothing wrong with that one either. I had replaced the thermostat in the 2001 thinking it was stuck open, but no help.
#28
THANK YOU to Tocoma5050 for doing all that work, and sharing it!
Glad to here someone else is having the same problem. Mine is a 2010 Civic EX 4 dr with 53k miles.
I am going to change thermostats with whatever NAPA sells me.
I have had trouble with factory Honda 'stats in the past, although it was on a (new) 2007 XR650R dirtbike. They stick open a little. or alot. but they all failed, not just some.
I really like Honda admitting guilt, but I don't remember having this problem for the last 3 winters, so I am convinced "something has changed". The thermostat is the easiest anwser. If it doesn't get cured, I'll just live with it.
#29
I had a 1990 Corolla that did this and it drove me insane, went through 3 thermostats, the only thing that somewhat helped was to make sure the temp was set to fully cold before starting the engine, which shuts the valve so only the coolant in the engine compartment was being heated, which helped it reach operating temp faster.
Its a shame the thermostats are only mechanical and there's no way to see what state they are in.
#30
Great thread.
#31
SO the heater core was more efficient than the radiator ?
#32
Was the fan working properly on the radiator? At low speeds, if the fan doesn't work, there's not enough airflow over a radiator to properly cool an engine (hence why the fans are there). When you turn the heat on inside the car, the fan under the dash moves a bunch of air over the heater core similar to how a radiator works.
#34
Great thread.
#35
Good points. If front bumper is allowing more air flow that may explain some temp drops while driving. But this morning I let my civic sit running in the driveway for 20 minutes and the temp gauge never raised at all. Also even if radiator is larger, I don't suspect that is the issue...because if the engine coolant is not at 180F then the thermostat should not be open and coolant should not be flowing through the radiator anyways....correct??
#36
I was considering trading in my 2010 Civic for a 2014…. “if” the 2014 does not have this same problem. But Honda will not tell me what the lowest outdoor temperature is that the 2014 Civic can reach 180F coolant temperature and maintain 180F. A Honda sales guy offered to check one out for me on a very cold day, but….Honda has done away with the temperature gauge in the 2014 Civics and so there is no way to verify what temperature the coolant is reaching (short of reading it from the ODB). Hmmm…I wonder why Honda did away with the coolant temperature gauge ;-)
#37
#38
1 Post
really no temperature gauge on the 2014? I really find that hard to believe unless it's part of that screen thing that comes up now.
#41
#42
#43
Hi vladd, I think there is a difference. With the temperature gauge in my 2010 Civic I can tell within 5 degrees what my coolant is at, so I could tell if it was at 85, 90, 95, 100, 105. ..etc.. 180, 185,190, 195...etc.
In 2014 Civic you can only tell two things:
1. that the coolant is over 180, but you have no idea if it's 181 or 205.
2. that the coolant is too low, but you have no idea if its 175 or 80
In the 2014 Civic if the TOO HIGH light comes on, you should pullover immediately since you have no idea its its at 181 or 200. But in the 2010 civic if your coolant was too high, say at 182, you could probably drive to a service station if it was only a few miles away.
#44
I see this conversation has been going on for a long time with no resolution. That's too bad -- because I have the exact same problem and was hoping to find the answer here. My 2009 Civic also has slow-and-low heat during the NY winter. Last year I had the thermostat replaced with an OEM 180 degree model. No change! Last month, I had a new Wagner 195 degree thermostat installed. No change! The digital gauge never reaches the midpoint, and heat/defrost is just warm. I've had a series of Accords and Civics in the past and all had great heat. I guess there is no solution. I'm sure it's affecting my gas mileage, which is also disappointing. Bummer! Thanks, all.
#46
Yesterday, I tried Doublethink's trick that worked on his Corolla. I turned the TEMP control all the way down before I started driving. Sure enough, the gauge reached 3, 4 and 5 LED segments more quickly than usual. BUT, I FROZE WHILE I WATCHED IT RISE. Then I turned the TEMP higher, and the gauge dropped down to 4, 3, and 2 bars. It took a long time to rise again, and never reached the normal midpoint. Hence the heat was only warm after that exercise. Looks like Honda screwed up on this one.
#47
Wanted to add, it's normal for the temp to drop back down if you don't wait long enough. I'm driving my Integra right now, it's -5 to 20 F in the morning when I get off work. If I turn the heat on as soon as the temp reaches normal, it'll fall back down for a while before reaching normal again (driving on the freeway). And yes, it's cold.
#48
So lets say it opens at 180F then it takes the whole radiator to pressurize a lot longer than say a radiator that is half its size. So it takes twice as long to heat a bigger radiator in -30c temps than say a radiator that is half the size.
i think the thermostat opens at below 180F or opens a little bit but definitely before the temp hits 180F. That means there is coolant circulating the entire system before the cars temp gauge reach half way. so even if the thermostat opens a little say at 160F then its still has to heat 2X (civic 2010 radiator) liters of coolant as opposed to x liters (small radiator) of coolant which is what taking so long.
if you let your car sit for 20 min. first thing in the morning it will never reach half way on a very cold day.
#49
08 civic with basically the same complaint and symptoms. this is my first winter with the car, first off I installed a new Honda thermostat with no change. Knowing the only way to improve the situation was to block airflow, I covered the entire lower bumper opening with a black garbage bag.
It's not ideal but I have good heat and the engine is operating in the normal range, and a bonus my gas mileage has improved to what I was getting in summer.
#50
