10k mile inspection
10k mile inspection
What is recommended to be done at 10k miles. I have had one oil change. Btw its a 3 yr lease n have had it since july 07' and that makes any difference. I need to get an oil change. Do I rotate tires? Anything else?
Re: 10k mile inspection (teggy2154)
Do whatever your maintence minder says if you wanna go by the book... at 10k here in vegas we do usually just oil/filter changes and rotates (if needed)
Re: 10k mile inspection (FBPSidan)
the stuff at 10k is tire rotation mainly possibly an alignment after that. But the dealer will tell you they will inspect bouch of stuff such as brake and all fluid levels etc. Oil change is kind of on it's own, you'll change it everytime it gets low on the %.
If you gonna buy the car, then do whatever you feel it's good for the car, but if you are not buying it at the end, then do only what's required I guess.
10K:
-front brake service (clean and lube caliper sliders)
-rear brake service
-lube oil filter
-lube door hinges, hood hinges, latch, battery terminals
-rotate tires
-top off all fluids
thats pretty much it...
alignment is reccomended every 15k
-rear brake service
-lube oil filter
-rotate tires
-top off all fluids
chiquito
Honda Civic (2006 - 2015)
64
03-21-2008 11:07 AM
socallmechris
15
01-20-2008 09:44 AM
AutoXer
13
09-08-2005 12:11 PM
JDMflavor_EJ
16
05-18-2004 03:32 PM
