***OFFICIAL 8th Gen General Discussion/Rant/INTRODUCTIONS Thread***
#5976
Re: ***OFFICIAL 8th Gen General Discussion/Rant/INTRODUCTIONS Thread***
I wouldn't waste my time and money on the HFP brake kit. It's only rotors and pads. Just get some OEM replacement rotors (Brembo blanks, Centric, or powerslot if you really want slotted) , some better pads (Hawk HPS, Axxis Ultimates), and some DOT 4 brake fluid. That would probably be better performing than the pricey HFP brakes. You can even get stainless steel lines with the price difference!
Unless you really need to have the red painted bits..
#5977
Hi. I'm new. 07 Si (Sedan). Brownish color. Got a parking ticket that said it was gray... ha!
My other car is 02 SVT Focus that I planned on driving forever. But, it's currently garaged with a new engine waiting to be dropped in. I have to admit, I had my doubts about this VTEC thing, but it surprised the crap out of me when I hit it the first time. Hopefully, after I get all these TSB's out of way, this Civic will have a long and happy life with me and my family.
#5978
H-T White Ops
Anyone else hear a clicking sound when your wheel is being turned?
Not really familiar with drive by wire and all, but I've never noticed it in a car before. It's only occasional.
#5979
I am not sure, but I have a sneaking suspicion that it's the front LCA compliance bushing. It has been talked about on 8thcivic.com with some full metal replacement bushings out there now (full race, blox, password jdm). I think I might be having the same issue with my car at 91K miles now.
#5980
H-T White Ops
The car seems to make this noise while not moving even. I have no idea. It's a 2010 Si coupe.
#5981
If you're still under warranty, I'd say take it in for an appointment and have Honda take a look. Maybe something in the suspension is loose? Is it happening on any particular side of the front?
#5982
H-T White Ops
I might have to bring it into Honda while he's at work. I hope they don't give me bs about bringing a car in when my name isn't on it. He just works six days a week and an hour away so it can get difficult to get stuff done.
#5983
NOFX the problem is more than likely the steering rack, you're hearing steering rack knock/pop/clunk. Iirc they're four bolts that secure the rack to the sub frame, just loosen them and tighten them back down.
#5984
H-T White Ops
Those are just replacement lower ball joints. That would have more to do with wheel hop then noise.
#5985
Theirs a tsb for it, it might be outta range but still do it. Mine was a 09 made at the very end of that year, and wasn't to far outta of the suggested range still had the problem.
#5986
Do you have the tsb number I think I have the same thing going on in my 09 it sounds like a clicking from the engine bay when turning the wheel happens when moving or at a stop would love to get it fixed, I still have under 20k on the car
#5987
Service Bulletin 09-028 Dated July 16, 2009
Clunking, Popping, or Clicking Noise From the Front While Turning
SYMPTOM
There is a clunk, pop, or click coming from the front of the vehilce when making a left or right turn at slow speeds.
PROBABLE CAUSE
The steering gearbox mounting bolts are not torqued correctly.
VEHICLES AFFECTED
2008 Civic
From VIN 2HGFA1...8H516998 thru
2HGFA1...8H599999
From VIN 2HGFG1...8H546508 thru
2HGFG1...8H599999
From VIN 2HGFA5...8H705832 thru
2HGFA5...8H799999
From VIN 2HGFG2...8H704505 thru
2HGFG2...8H799999
2009 Civic
From VIN 2HGFA1...9H500000 thru
2HGFA1...9H525040
From VIN 2HGFG1...9H500000 thru
2HGFG1...9H539364
From VIN 2HGFA5...9H700000 thru
2HGFA5...9H708331
From VIN 2HGFG2...9H700000 thru
2HGFG2...9H704887
CORRECTIVE ACTION
Retorque the steering gearbox mounting bolts.
If Honda won't do it, you can DIY http://www.8thcivic.com/forums/do-yo...clunk-pop.html
Found this in the thread too...
SYMPTOM
PROBABLE CAUSE
VEHICLES AFFECTED
2008 Civic
2HGFA1...8H599999
2HGFG1...8H599999
2HGFA5...8H799999
2HGFG2...8H799999
2009 Civic
2HGFA1...9H525040
2HGFG1...9H539364
2HGFA5...9H708331
2HGFG2...9H704887
CORRECTIVE ACTION
#5988
H-T White Ops
I did just get him the TWM shift ****, which he's in love with. First mod ever.
#5989
SYMPTOM
PROBABLE CAUSE
VEHICLES AFFECTED
2008 Civic
2HGFA1...8H599999
2HGFG1...8H599999
2HGFA5...8H799999
2HGFG2...8H799999
2009 Civic
2HGFA1...9H525040
2HGFG1...9H539364
2HGFA5...9H708331
2HGFG2...9H704887
CORRECTIVE ACTION
SYMPTOM
PROBABLE CAUSE
VEHICLES AFFECTED
2008 Civic
2HGFA1...8H599999
2HGFG1...8H599999
2HGFA5...8H799999
2HGFG2...8H799999
2009 Civic
2HGFA1...9H525040
2HGFG1...9H539364
2HGFA5...9H708331
2HGFG2...9H704887
CORRECTIVE ACTION
#5990
1 Post
Do any of you experience like a rubbing sound when taking off?
Basically in the morning when I start my FA5 and I put it in first gear and start releasing the clutch and taking off you hear a rubbing sound. Like there is some sort of friction... It does it for a few minutes until it's all warmed up... Do you guys experience this?
I changed my transmission oil recently which was the Honda MTF... do you guys use something better? or would you suggest something better for the LSD tranny?
Thanks for the help
Thanks for the help
#5993
First off I'm a tech at a Honda dealership so when it comes to my cars I'm kinda lazy after working on cars all day. I have an 06 2 door and I have 2 questions, Does anyone's clutch pedal make a crunching/creaking sound? And 2 what is a good suspension set up, either Springs or Coilovers? I have heard nothing bad about the Eibach Pro Kit just looking for some advice here thanks.
#5994
Depends on your goals or future set ups, how much you want to spend. I had S techs, now I have go power coilovers. Don't waste your money buying both.
#5996
I work at a Honda Dealership and there was an 06 with Skunk 2 coil overs and when we put it in the air the spring almost fell out from the rear, is this just with skunk 2's or all coil overs on these Civics? I know it was because the car was slammed that the spring almost fell out but are all of the coil overs like this?
#5997
That's normal the spring is a lot shorter compared to oem. What were they, pro c or pro s? Nothing much ken, I'm starting to think about selling the civic again. I'm watching obama speak and he's actually not using a teleprompter, it certainly changed his tempo of speech. It sounds like he's giving a sermon.
#5998
I know the spring are way way shorter but i was wondering if all the other types of coilovers are like this too?
#6000
Buddy and I are going to start fabricating some parts for the 98 coupe. Decided against going NA and decided to do a turbo car for once. Will be a budget build and nothing serious. Looking for 250-300 whp. Most likely going to use a TD05 Evo 3 big 16g turbo. Small I know but will do its job and be reliable.
