Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
yet another LCA bushing ?
Old 03-19-2008, 04:19 AM
hydengr's Avatar
Default yet another LCA bushing ?
All,
My 05 EX Sedan w/ 45,000 miles has developed the dreaded "thump," audible during low speed bumps, that points me towards the LCA bushings.
From searching, it appears that many feel that the PCI LCA Spherical Bearing, like the ones available from CLUBRSX, are the way to go.
My question is, "Is there anything else that should be replaced at this time? Will this mod have any adverse impacts to rest of the suspension components? The info that I'm looking for is similiar to the "If you replace the rear anti-roll bar with a beefier unit, you should upgrade the end links too." At this time, I feel that all of the other front end suspension components are sound...
Thanks in advance.
Old 03-19-2008, 04:25 AM
Sanji
toyomatt84's Avatar
You really won't need to upgrade all that much, to run the replacement bearings. If you were riding extremely low, then that'd be an entirely different situation.
Old 03-19-2008, 06:23 AM
hydengr's Avatar
Default Re: (toyomatt84)
toyomatt,
I'm running 100% stock as this is my DD. So... what is "all that much" in terms of upgrading?
Guess my question is, "can I just replace the OEM LCA bushings w/ the PCI Spherical Bearings w/o any other mod and be good to go...?"
Again, thanks for the info... This site has been very helpful.
Old 03-19-2008, 06:30 AM
Sanji
toyomatt84's Avatar
Default Re: (hydengr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hydengr &raquo;</TD></TR><TR><TD CLASS="quote">"can I just replace the OEM LCA bushings w/ the PCI Spherical Bearings w/o any other mod and be good to go...?</TD></TR></TABLE>
Yes, you can.
Old 03-20-2008, 11:21 PM
RedEG8's Avatar
Default front LCA HELP!
Just wanting to know if their are any thing i should watch for when changing them?, a decent shop that could do it besides honda...any kinda of tips would be great a help thanks
Need to replace since my ride hit a curb and has a slight bent with positive camber
Modified by RedEG8 at 12:34 AM 3/21/2008
r_kage
Suspension & Brakes
06-09-2015 12:41 PM
blueandy
Suspension & Brakes
03-13-2013 07:15 PM
rugimpy
34
04-14-2011 02:39 PM
Mach30SiR
09-14-2004 01:25 PM
Cryptopsy
01-30-2003 10:38 AM
Quick Reply: yet another LCA bushing ?
