Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
shifting problem
Old Nov 21, 2006 | 12:32 PM
doboy8689's Avatar
Default shifting problem
i got an 01 civic ex and lately when i go to shift either from 1st to second or downshift from 2nd to 1st, it seems to be REALLY hard to get the shifter into gear and it also makes a squeak/grind noise. Could that be my synchros starting to go? i hav about 84000 miles on the car and have never drained/refilled the tranny fluid. should i try that and maybe put some lucas additive in with the refill and see what happened? i am really trying to avoid gettin a new tranny so i just wanted to know if this has happened to n e one else and if they did anything to correct it... if someone could let me know i would appreciate it--thank you!
Old Nov 21, 2006 | 12:38 PM
Miracle's Avatar
Default Re: shifting problem (doboy8689)
My first assumption and reccomendation would be to do a full flush and refill on the transmission/transaxle fluid. Get ALL of the old stuff out of there, and refill it with new fluid.
If the problem still persists, I would suspect the synchronizers first and foremost.
Is the grinding/squeak coming from the transaxle case itself, or from the cable/connection?
Old Nov 21, 2006 | 12:49 PM
doboy8689's Avatar
to be honest it sounds like its coming from the cable connection but hey i could be wrong? its kind of hard to tell
Old Nov 21, 2006 | 03:32 PM
JDM_ESK1's Avatar
maybe the bushing for the shifter are worn out?
Old Nov 21, 2006 | 05:00 PM
cranny's Avatar
24.224.233.247
Default Re: (JDM_ESK1)
my 01 did the exact same thing first year i bought it. they spray some kind of crazy undercoating under it. and the first winter , was stiff going from 3rd to 4th(mainly) , and 1st to 2nd , back and forth. if i remember correctly , it was stiffer going one way than the other , sound the same? could be debris in the shift linkage or under hood on the tranny where cables hook up. also i might add , never sit anything in the boot , makes it so it wont go in gear , lol.
tpod
Jan 4, 2007 12:49 AM
globy123
Dec 25, 2006 09:24 AM
B16Jacques
Sep 15, 2006 04:06 PM
bluels-t
Dec 13, 2004 12:37 PM
ChingonGSR
Apr 18, 2003 11:16 AM
