Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Remote Starter Problem
Old Jun 3, 2006 | 07:14 AM
peetish13's Avatar
Default Remote Starter Problem
i have a 2002 honda civic. for some reason i am only able to start it with the remote starter and when i do the lights flash and there is a clicking sound in the car. if i try to start it with the key, nothing happens except for the same clicking and light flashing. i've had the car for about 3 months and i never use the remote starter, always the key, so i have no idea what could be going on. any suggestions or advice on this would be greatly appreciated. thanks.
Old Jun 3, 2006 | 07:17 AM
toyomatt84's Avatar
Sanji
I've never seen a Remote Starter kit for our specific model Civic. The "clicking and flashing" is just you locking/unlocking the door. Are you sure you're just not using the unlock/lock key fob that comes with most Civic's?
Old Jun 3, 2006 | 07:33 AM
peetish13's Avatar
Default Re: (toyomatt84)
the clicking and flashing is not unlocking or locking the door. it happens when i turn the key in the ignition...the car doesn't start, the lights begin to flash both inside and out and a clicking sound also begins. after trying with the key a few times, i tried starting the car with the remote starter and it started, but when i took the car out of park the lights again began to flash along with the clicking. the car will not start with the key at all and i can't figure out why. when i start it with the remote starter, it starts fine, but the lights are still flashing and there is clicking.
Old Jun 3, 2006 | 08:16 AM
toyomatt84's Avatar
Sanji
It sounds like you don't have a properly matched key with your car. There's a chip inside your key that your car recognizes.
Old Jun 3, 2006 | 08:46 AM
fventura03's Avatar
which remote start do you have? they don't come factory with remote start.
Old Jun 3, 2006 | 10:29 PM
fg2si!kid's Avatar
New User
Default Re: Remote Starter Problem (peetish13)
that clicking sound might be a relay under the dash
Old Jun 3, 2006 | 10:38 PM
fg2si!kid's Avatar
New User
also it sounds like your remote start system is not leting your ignition start the car the unit is creating an open at the igntion so only the remote will start the car also the unit it self might be bad look at the wireing too take a look at the condition of the wires if you know your wireing you might be abel to bypass it but then only your key will start the car but thats just an option
RMS94EG8
Nov 18, 2015 12:16 AM
dylokjai
Dec 29, 2004 03:55 AM
TABIAS
Apr 10, 2004 04:09 PM
civicbro
Feb 19, 2004 02:47 AM
