P1457 Code???
I FINALLY fixed the problem. I first replaced the :"2 way shutoff valve" on the driver's side of the canister. That didn't solve it. Next I replaced the "purge valve" under the air cleaner,That didn't work. Then I changed the "shut off valve" on the passenger side of the canister. That WORKED!!! I took the entire canister out to replace that last part. Good luck and if I can help, let me know.f
Another problem I found is the tube attached to purge outlet on the charcoal canister. About 3 inch long metal tube is not covered by rubber, which is rusty badly. I am thinking how to fix it now.
Use a tape covered the 3 inch long metal part. The code has not come back in a week.
This is another Honda stupid design. Why is to expose this short metal tube to air? Is it difficult to cover it by rubber like other parts in the tube?
