Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
hooked up a system car cranks wont start not battery
Old 09-13-2013, 03:29 PM
blind951's Avatar
Default hooked up a system car cranks wont start not battery
Ok so I was hooking up a system in my 01 civic and when I hooked up the power to the battery at the very end I went to turn on my car. The car cranks and sounds like it wants to start but won't turnover. I hooked jumper cables up just to see and that dosent work so I don't think its the battery any ideas?
Old 09-13-2013, 04:03 PM
lazlong's Avatar
Default Re: hooked up a system car cranks wont start not battery
1. What components did you install or replace?
2. How big an amp?
3. Did you accidentally wire the ignition wire for the amp to an always hot wire?
Old 09-13-2013, 04:30 PM
lowlife9's Avatar
check your grounds hopefully you didn't fry the ECU is the check engine light on at all ??. check for codes also check your fuses i blew a couple fuses installing my system.
blind951
09-16-2013 07:07 AM
LOWLIFEHATCH
Audio / Security / Video
03-31-2005 02:05 PM
hopsta
09-29-2004 04:01 PM
4drZCG
10-29-2002 01:03 PM
Quick Reply: hooked up a system car cranks wont start not battery
