Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Help: how to replace driver's side window
Old Jul 7, 2010 | 10:06 PM
aznomb's Avatar
Default Help: how to replace driver's side window
my car just got broken into and the driver side window is broken. can some post a tutorial on a diy on how tp replace the window? it a power window on a 03 civic lx
Old Jul 7, 2010 | 10:15 PM
It Wasn't Me's Avatar
Default Re: Help: how to replace driver's side window
https://honda-tech.com/forums/honda-civic-2001-2005-78/anyne-know-how-change-window-reg-2798364/
The glass should be relatively easy to replace once you remove the door panel and can see inside the door.
We don't have a DIY for this, but I'll poke around a little to see what I can find.
Old Jul 8, 2010 | 04:07 PM
chawski's Avatar
i dont have pics, but its not difficult at all...
look behind the door latch from the inside. you will see a little cover with a slit that looks like it will fit a flathead in it. grab a flathead and pry it off...should come off easily, and it will expose 2 screws. take em out. then, around the trim where the window switches etc are, pull the front bottom part off. its a bit tricky, but its all pressure tabs. that will expose 2 more hex screws, the back one likely requiring an extension on a rachet to get to. once those are out, pop the door latch behind the door card. work around the perimeter of the door card and pop all the little tab things (maybe 8 or so around the perimeter). now just lift the door card over the lock and its off.
Once it off, theres about 3 screws holding in the regulator. once you can see everything from the inside of the door, it should be pretty self explanitory to get the window out and get the new one in. figure about an hour to get it all out and then no more than 10 minutes to get it all back together (much easier once you see how to do it).
Old Jul 8, 2010 | 05:33 PM
Pictures for door panel removal are in the link I posted.
Old Jul 9, 2010 | 03:46 AM
chawski's Avatar
haha fail. well in case you want to actively read and not look at pics, see my post...if you wanna do it right, prolly wanna just use the link haha
Edit - after looking at your link, i have to congratulate myself for remembering there were 3 bolts holding the regulator in. its been a while since i was back there haha
BootcutSoldier
Oct 16, 2007 07:56 PM
DOHC_VTEC69
Feb 3, 2005 11:39 AM
Red_EM1
14
May 11, 2004 09:31 PM
RATEDR
May 23, 2002 06:39 AM
