Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
DIY: K20/K24 Swap into a 2001-2005 Civic
Old 09-16-2013, 07:02 PM
  #26
Sanji
toyomatt84's Avatar
Default Re: DIY: K20/K24 Swap into a 2001-2005 Civic
Originally Posted by Twizted Shifter
In the write up it says the wiring hasn't been tested with a k24? Or is the wiring on a k24 and k20 the same? Any help would be appreciated
The K24 has different crank position sensor wiring (reversed) and an entirely different charge harness and ECU connection.
Old 02-28-2016, 06:11 AM
  #27
Bo Sprocket's Avatar
would there be any difference doing this swap into a 4 door? wondering mostly about the subframe
Old 02-28-2016, 09:19 AM
  #28
Sanji
toyomatt84's Avatar
Nope.
Old 04-02-2016, 12:34 PM
  #29
oxxy's Avatar
Hi, i was just swapping my 01 civic using a k24 mixed with k20. The head and gearbox belong to the k20 and some internals. Im choosing hondata kpro v3 for the ecu. While dynoing, i found that the vtec was not engaged. But i didnt see any CELs in the first place. The tuner checked and found that the vss isnt responding. Trouble code 16 if im not mistaken. And im sure that the speedo stays at 0 while dynoing. Any suggestion to fix the issue ? I've tried changing the ecu/vss both. Still dead end. Or maybe i should use the emk2 harness ? Anyone facing the same problem before ? Please do share. Thanks.
Old 04-02-2016, 11:02 PM
  #30
Sanji
toyomatt84's Avatar
Your transmission will yield different results depending on what year DC5 you pulled it from. 02-04 is different the 05-06 with regards to the signal from the VSS.
Old 04-03-2016, 03:55 AM
  #31
oxxy's Avatar
Im using the 02-04 dc5 gearbox. What would be the difference in those 2 production years ?
Old 04-03-2016, 10:14 PM
  #32
Sanji
toyomatt84's Avatar
They're different sensors, all together.
Old 04-03-2016, 10:37 PM
  #33
oxxy's Avatar
Okay, like i said im using the 03 gearbox to be exact. So why does the speedo and vss not responding to the hondata ? My tuner said the vss is giving signal, but not reaching the ecu. I wonder whats happening and the tuner himself cant figure this one out. Is the k-tuned emk2 harness is going to help ? I was about to buy one but my tuner cant guarantee that it'll work. Thats why i ended up asking so many questions here.
Thanks for your time toyomatt84
Old 04-09-2016, 06:27 AM
  #34
ok so my 03 4door is now k24 ready rsx spindles and anti sway bars all around with type s brakes. sitting in the scrap yard is a 4wd k24 crv, is it just a matter of swapping tranys to make it fwd, if so i have access to rsx base model (unfortunately with semi auto box) would this work for now till donner car comes along for head and 6spd swap?
Old 04-09-2016, 11:23 PM
  #35
Sanji
toyomatt84's Avatar
Well, if the VSS is sending a signal, you need to find out why its not reaching the ECU. There's a short or improper link somewhere.
Semi-auto box? What transmission are you referring to? There's an automatic, and a manual option for the RSX.
Old 04-10-2016, 02:49 AM
  #36
auto box that has a separate slot for up/down shifts i know it's really an automatic (do we refer to this as honda-matic, sport shift?or just plain automatic?) also are there any other rads that will work(only si's i can find at the moment are 1.7 cdn. version, and 2 rsx's both front end crashed) thanks again toyomatt84
Old 04-10-2016, 10:56 AM
  #37
Sanji
toyomatt84's Avatar
No, that's just an automatic really. And, no, it won't work as a solution temporarily, because it has different mounts and there's no way to tune it, unless you run a completely factory setup (ECU included).
As for radiators, you're looking at DC5 or EP3 for options, sadly.
Old 04-14-2016, 02:13 AM
  #38
i found someone selling an rsx subframe, are there any measurements i can make to determine if its strait?
Old 04-14-2016, 08:54 PM
  #39
Sanji
toyomatt84's Avatar
There are 4 mounting locations that attach the DC5 subframe to the car, that are shared with the EM2's factory subframe.
Old 04-15-2016, 04:40 AM
  #40
lol gettin out the jack stands and tape measure!!!...duh
Old 10-05-2016, 06:42 PM
  #41
Mono Perez's Avatar
I have 03 honda civic but i want to do a swap on it but idk if i have to change my tranny too??
Old 10-05-2016, 07:10 PM
  #42
Sanji
toyomatt84's Avatar
Yes. The engine mounts on the opposite side of the bay and spins a different direction.
Old 02-20-2017, 06:49 AM
  #43
SunriseSunset's Avatar
Could someone please update the link to the DIY. The K20/K24 swap URL domain expired and it's no longer online.
Old 02-20-2017, 08:09 AM
  #44
Fish Twig
tony_2018's Avatar
Please READ the 1st post.
Old 02-20-2017, 09:56 AM
  #45
Thanks friend, my fault. I overlooked it so bad. Thanks
Old 03-31-2017, 01:58 PM
  #46
Samtunning's Avatar
Originally Posted by xproductionz
Click here for the DIY... i have it sitting on my server
xproductionz.com*-*xproductionz Resources and Information.
Since website is no longer available, I have uploaded a PDF of the web page. Please see attached. -toyomatt84
As i go along let me know if i missed anything so i can add it in
Also if anyone has some pics i can add then that would help too
UPDATED 3/5/2006
**also note that the same thing applies to people who do the k24 swap. Just remember that if you use a k24 that the tranny side mount is different from the k20 tranny mount. If you already have a k20 in your car and wish to use a k24. Hasport and i think Hybrid can supply only the k24 tranny mount so that way it sits the motor lower so it can fit in our cars
***also note that i did find out that the 04-05 civics have the in-dash c101 clip rewired from that of the 01-03. I am in the process of finding out the solution for you 04-05 owners. If anyone has figured it out please do let me know so i can put it up
Does anyone know the c101 connector pinout for the 04-05 em2 I can't figure out the wiring need help
Old 05-07-2018, 10:56 AM
  #47
honda_12V's Avatar
Hey
I hope someone can answer
I want to use a k24 engine and k24 box into a em2.
What mounts do I use?
Regards
Old 05-07-2018, 11:01 AM
  #48
thisguyaves's Avatar
Originally Posted by honda_12V
Hey
Regards
Last I checked, K24 transmissions are longer than the K20s (Civic Si, RSX) and will not work. Speaking from experience, I wanted to put a TSX transmission in my EP3 and was told it didn't fit.
Edit: Mounts are different on the transmissions.
Old 05-07-2018, 02:43 PM
  #49
Sanji
toyomatt84's Avatar
The casting is also different on the transmission, and won't clear the rail. You'll need a K20 transmission housing at least.
Old 05-07-2018, 03:15 PM
  #50
You know, that's what I thought, but I just wrote it off as being not feasible and never remembered why exactly.
Quick Reply: DIY: K20/K24 Swap into a 2001-2005 Civic
