buzzing noise behind dash
Hey guys i just got a 01 civ si-g, just started hearing a buzzing noise coming from behind the dash when i turn off my lights, it goes away when i turn my lights on, You guys think its a relay?
Re: buzzing noise behind dash (Crunk'd)
I hear a buzzing as well in my '02 si. I only hear it after shutting the engine off. It turns out the rear light in the headliner over the rear seats emits a buzzing noise as it dims.
Re: buzzing noise behind dash (null2k2si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by null2k2si »</TD></TR><TR><TD CLASS="quote">I hear a buzzing as well in my '02 si. I only hear it after shutting the engine off. It turns out the rear light in the headliner over the rear seats emits a buzzing noise as it dims. </TD></TR></TABLE>
lmao, mine does that too, ever since i got the car. i dunno, might be the bulbs they use or something. i never bothered trying to figure it out
My wife has this exact same issue with her car. Ever figure out what it was? Hers is a 2003 Acura 1.7el. Exact same model as a Honda civic.
So the culprit could actually in your door jams.
The switch that senses your door is closed is a NC circuit. When you close the door, the switch goes from being grounded to being open. If your switch is dirty or the door jam is rusty under the switch, it can give a poor or partial ground even when closed. As far as turning the lights on making it go away, I'd suspect the amp draw is suddenly enough to negate the small amount that dome relay is trying to pull
xunkn0vvnx
10-18-2017 08:20 PM
mojoski
01-03-2012 05:47 PM
fisofo
08-19-2007 05:50 PM
