Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- Honda Accord: Why does my engine oil flow into the coolant reservoir?
Guide to diagnose touble and recommended solutions.
► 01-05 Civic Cooling System Q&A (overheating, fans inoperable, etc.)
#276
Re: ► 01-05 Civic Cooling System Questions? Ask them here! (overheating, coolant, et
Hey what up man thanks for responding EM2 -- while I know you know your stuff, doesnt mean that because its overheating that the head has been damaged -- I agree 100% that if I keep on driving it like this that I will have to deal with having to resurface the head, would you agree? With that said I do plan on replacing all the parts that you have listed above -- for now though im using a FAL electric fan controller to override when the fans come on which ( just leave em on the whole time) til I can get all these parts together and then replace em all. What do you think?
#277
Yeah kinda pissed me off that my honda was acting up -- in my mind they are indestructible -- and for this to happen really bummed me out -- kind of off topic but since you know your stuff -- what do you think about this :Complete Gasket Set
MLS Head Gasket
Wiseco Performance Pistons
(75, 75.5, 76mm bore)
(8.8, 9.5, 10.5mm comp ratio)
Plasma Moly Rings
Performance Wrist Pins
Thrust Washers
TOGA Main Bearings
TOGA Rod Bearings-- for 925$$ heres the link http://www.importperformanceparts.ne...pek-honda.html
they say minimum of 40 ponies gain from these bad boys -- never heard of these guys though -- with stage 2 cams valves and retainers -- hondata kpro im thinking like 170- 180 whp
MLS Head Gasket
Plasma Moly Rings
Thrust Washers
TOGA Main Bearings
#278
You're not going to see 170whp, even with K-Pro. You're looking at 160whp tops, even with all that. For the money spent, you're also going to impact the reliability of the engine, as well.
#279
Hey what up Straw Hat -- you say I would effect the reliability of the car. I definitely dont want to do that. Im planning on boosting my EM2 -- how would I make a reliable car + a semi track car -- reason for all those internals is so that I dont blow through my engine when I hook it to a turbo planning on pushing rods too -- confused on how it would effect reliability though since I would be able to control pretty much everything through K-pro ( not doubting your info just stating my opinion ) -- I am a fore ever student.
#280
the D17 was not really "made" to be boosted... it has a plastic intake manifold, for crying out loud... that alone should say enough. i agree that it will all mess with the reliability of the car. even with a small turbo and low boost level, to me, its not worth all the hassle and extra maintenance. but if you dont mind the extra maintenance and all that jazz, then go for it. your motor will run hotter though.
#281
Tuning a car will make it the most reliable in its given condition... however, there are inherent design "flaws" in the D17 that limit its overall potential.
#282
yeah i hear you toyo -- so I thought I had fixed these problems but nope -- so on my way to me is
http://www.ebay.com/itm/01-05-Honda-Civic-Vtec-EX-HX-SI-1-7-MLS-Head-Gasket-Set-D17A2-D17A6-/220918667183?pt=Motors_Car_Truck_Parts_Accessories&hash=item336fc757af&vxp=mtr
i know ebay but they are just replacement parts -- rite? as well as water pump and timing belt -- how much to resurface the head.
#283
hey toyo and em2 thanks for all the info and help looks like I want to run before I can even walk -- this was all the proof i needed -- K20 here I come -- first I gotta get this running for now at least,, dont quite have enough for all those parts yet. Lets hope all is well after I do this.
#284
01 05 Honda Civic vtec EX HX SI 1 7 MLS Head Gasket Set D17A2 D17A6 | eBay
As for the K-swap, its truly a different car when you have a K. The power feels more "immediate" and within reach, during all ranges of the RPM band. Its a refreshing feeling, since (without the K) the car lacks very little in terms of desirable features, in my opinion. I fit in mine exceptionally well (being broad-shouldered and 6'2" makes this a challenge for many cars). And, no matter how many times I drive/modify/whatever to it... I'm always looking back with a smile on it. It makes me happy every day, and that's probably never going to change.
#285
Thanks for the info looked up some places and found one recommended by a honda tech member going to give em a shot once I get my car to my mechanic. K series have to make that happen soon. Either a vacation late this year or a k swap. Thanks again Straw Hat.
#286
on a last note for you... as someone once said... "if it's on ebay, leave it there."
essentially, your best bet to fixing your current problem is to use Honda OEM Replacement parts for that fix. anything else and you may likely run into the problem again. also, as matt said, the head resurfacing varies. i got mine done by a reputable place for $50 flat.
#287
PS. I did notice the reference to One Piece. Guilty admission: Sanji is tattoo'd on my back.
#288
Honestly, the K-series really is a fun swap. If you like most everything about the car, other then its lack of power... well, the K-series will certainly change your attitude about it.
Thats whats up bro,, Sanji is one koo dude -- hardcore -- toyo -- Props on the K swap and that tat.
#289
Yo Em2 -- I hear you bro -- but I did look into that company before I bought em-- had all kinds of good reviews not a single bad one on Ebay -- (which dont mean much) but then I looked em up online and they popped up on forums too -- apparently their batting average is up their my dude. What do you think.
P.S where you get that head resurfaced?? Im from the SD too.
#290
i had it resurfaced out here in the LA county. perhaps a 2.5 hour drive for you. dunno if you wanna make that trip just to get the head resurfaced. lol but you might. i dunno. maybe make a nice trip out of it?
#291
I think the first post should be updated to keep things simple and it's as simple as this...
If you own an 01-05 Civic and you experience any kind of overheating, you need a headgasket. If it was caused by the fans not coming on or a faulty thermostat, if the headgasket was fine before that, it won't be after the fix.
Come to my dealership at any given time and you will find atleast one of these cars in it getting a headgasket.
#292
#293
Lil update on that overheating I had going on -- took it apart detached the head and what do you know no blown headgasket what still completely intact -- I ended up buying the full gasket set they sell at orielly's autoparts -- too -- so since we had the head off -- we decided to might as well go all the way and tear it apart all the way -- bad surprise waiting for me too -- clutch was basically done -- would have been a nightmare to have done all that just to go and take it apart in like 2 weeks -- soo now were thinking water pump -- because head gasket was good -- we replaced radiator with cap -- thermostat -- thermostat sensor -- radiator fan switch -- and nothing so this week looking @ replacing all those new gaskets -- picking up the head today from machine shop -- can anyone think of anything else!!?? --- also all new hoses are going to be used --
#294
#295
yeah I hear you thats the concluxion I came to. Re read your post and saw that you mentioned that -- I did have it machined shopped. I get that bad boy tonight or tomorrow nite so im def pump,, theirs that part inside me that's stressing out though keep thinking something else is gonna go wrong you knows. --- Once again thXX for your help homie.
#297
Over heating problems help!
So my wife was driving my 2005 civic one mourning and the car she put on the heat and it started to overheat then i towed it to the shop they flushed my civic pressure tested the coolant system replaced my radiator cap and laughed at me and told me its not broken because it never overheated for them! A week later i was driving i turned on the heat and it overheated i towed it to the shop and they said oh your water pumps leaking they replaced it! I went on my way for about a week and they replaced the thermostat & said it might be an airbubble in the system so they sucked it out and now its a week later and the damn thing is overheating again! Is it a head gasket?! I dont know what else it could be! It is only when the heat is on that it over heats and if i pull over the car will cool down within 5 minutes! Sometimes it will be fine after that and sometimes itll over heat again 10 minutes can someone help me! Is it a head gasket? the fan turns on so its not that and theres no leaks of coolant anywhere in plain sight but when i check for bubbles by taking off my radiator cap i dont see any and theres no white smoke in my exhaust!
#298
Re: Over heating problems help!
this should help:
https://honda-tech.com/forums/showth...hlight=cooling
