Those of you with ITR knock-off shift knobs
Old Jan 3, 2003 | 08:00 AM
p nut's Avatar
Default Those of you with ITR knock-off shift *****
I just got mine last Fri, and I just tried to put it on. But it only screws down a few turns and then it won't go anymore. Did you guys have to saw some of the shifter off?
Old Jan 3, 2003 | 08:17 AM
mantic6t9's Avatar
Default Re: Those of you with ITR knock-off shift ***** (con)
If you're using the nut that came with it throw it away and just screw the **** on. If you arent using the nut then i don't know what to tell you.
Old Jan 3, 2003 | 09:47 AM
9KRacer's Avatar
New User
Default Re: Those of you with ITR knock-off shift ***** (mantic6t9)
Mine has started to turn more than it should..
Old Jan 3, 2003 | 10:17 AM
integobsession's Avatar
I've never heard of that from ITR knock offs.... Did you have your OEM shift on there before the wannabe ITR one? If so, what kind of shifter do you have on your car...
The reason that I ask is because if you have an aftermarket short shifter and you had the stock plastic shift ****... and now the ITR shift **** won't go on the shifter, then your problem is the threading on your short shifter. The reason you didn't notice before with the oem **** is because the threading is made out of plastic and you could screw it - and eventually re-thread the the **** unknowingly. That's actually what skunk2 told me when I purchased their short shifter...
Old Jan 3, 2003 | 10:19 AM
Default Re: Those of you with ITR knock-off shift ***** (9KRacer)
Go to a hardware store and purchase some lock-tite... that stuff'll keep that **** right in place.
Old Jan 3, 2003 | 02:02 PM
p nut's Avatar
Default Re: Those of you with ITR knock-off shift ***** (integobsession)
I have the OEM shifter on there. I'm thinking it's the POS shift **** I got that's screwed up.
Old Jan 3, 2003 | 03:55 PM
Deluzional's Avatar
I turned mine way too much and now i cant take it off
Old Jan 3, 2003 | 04:20 PM
hanson said's Avatar
try tearing little bits of paper, wadding them up, and then stuffing them into the top of the threads on the ****. this will let you adjust how high/low you need it, and still be able to screw it down plenty tight. not exactly the fanciest fix, but it works darn well.
Old Jan 4, 2003 | 10:25 PM
PornstaR16L's Avatar
Default Re: Those of you with ITR knock-off shift ***** (hanson said)
man that really sucks you spent like what ... 40 bucks on a knock off and
I got mine free when my uncle -who lives in japan- sent me a set of JDM
headlight and its the S#!T............. good luck
Old Jan 5, 2003 | 12:09 AM
VrInteg's Avatar
New User
Read what you just posted again...
Old Jan 5, 2003 | 07:43 AM
Hexxboy's Avatar
New User
thats exactly what I did
Old Jan 5, 2003 | 01:48 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Those of you with ITR knock-off shift ***** (krrrrrrzyrebel)
This is off topic..but I had my ITR knock-off installed.
So wait.... you had your shift **** installed?Umm.... ALRIGHTY THEN.......
jdmericteg
May 20, 2015 08:23 AM
lickety_britches
Aug 3, 2007 06:25 AM
keeganl
Feb 28, 2007 05:44 AM
exclusive_vtec
May 19, 2004 08:21 PM
Buckshot
Feb 5, 2003 10:50 PM
