♠ Shaved, Tucked, Customized Engine Bays - Pics, Theory, Discussion ♠
#3829
Re: (EF8kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8kid »</TD></TR><TR><TD CLASS="quote">for people who said u shouldnt block off the ports on the PS racks...
Do you see OEM racks with vents? No.</TD></TR></TABLE>
I dont see your point.
Vents = breather? Of course oem wouldnt have them the fluid is getting pumped around the system under pressure...
#3830
Re: (h22apwrdcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22apwrdcivic »</TD></TR><TR><TD CLASS="quote">ok so this is my very first attempt at welding so if you see flaws dont hate im learning.
its ok you grind them anyways
#3831
Re: (EF8kid)
its ok you grind them anyways </TD></TR></TABLE>
You should see chases welds!
#3832
Re: (EF8kid)
yeah i got a lot of that to do. still gotta fill the big holes with the sheet metal and do the seam welds. ran out of welding wire.
#3833
Re: (h22apwrdcivic)
yeah i got a lot of that to do. still gotta fill the big holes with the sheet metal and do the seam welds. </TD></TR></TABLE>
i know all about that. Grinding is fun! Sanding filler....not so much.
#3834
1 Post
Re: (EF8kid)
the fluid needs to be able to circulate from one side of the rack to the other. if its blocked off, there is no way for it to circulate.
lke i said before, i doubt all of the realtime racing dc5's and tsx's would use the loop/brether if there were no point or if it wasnt reliable
#3835
Re: (SHG_EasyE)
I need a recomendation for a cleaning product for my engine bay. They guy who owned my car before me had it undercoated, and when I got it they had gotten the undercoat rubber all over in the engine bay. What's a good cleaner to to scrub that off with? Some places its kinda gooey, and someplaces it's dried. I know it sucks that it's like that, but it's a totally rust free ef in WI!
#3836
Re: (SHG_EasyE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHG_EasyE »</TD></TR><TR><TD CLASS="quote">
lke i said before, i doubt all of the realtime racing dc5's and tsx's would use the loop/brether if there were no point or if it wasnt reliable</TD></TR></TABLE>
evan knows his ****...
#3837
Re: (SHG_EasyE)
The rack needs the fluid to be recirculating as seen in the Honda Tuning issue. The only reason why it recirculates is to lubricate the rack and pinion. The powers teering fluid also acts as a lubricant so the rack does not seize.
#3839
Re: (LFA Squad :: Catfish)
valuble steering rack info
think im gunna loop and breather, im using a clutch fluid reseviour atm, will that allow enough ventilation for the pressure to disperse when turning or should i drill some holes in the lid?
Also does anyone have a pic or can describe what the seam welds should look like before bondo? im really considering doing this.
again, good info guys
#3840
1 Post
Re: (ezza)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ezza »</TD></TR><TR><TD CLASS="quote">valuble steering rack info
again, good info guys </TD></TR></TABLE>
we actually tried using the clutch resi on my freind's ek, it tended to overflow when going to full lock really quick, its not a large enough resivior.... i would try something a bit larger, or be careful not to put too much fluid in it.
#3844
1 Post
Re: (DarkBB4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkBB4 »</TD></TR><TR><TD CLASS="quote">can i mount the clutch master cylinder resevoir anywhere above the cylinder?</TD></TR></TABLE>
yeah, we ounted it up to the left of the brake resivior, theres a 10mm hole there already and they line up nicely next to eachother
#3845
Re: (SHG_EasyE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHG_EasyE »</TD></TR><TR><TD CLASS="quote">yeah, we ounted it up to the left of the brake resivior, theres a 10mm hole there already and they line up nicely next to eachother</TD></TR></TABLE>
have any pics? I'm thinking about mounting mine in the cowl where the wiper motor used to be, but I won't be able to see if it gets low...
#3847
1 Post
Re: (teal_dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teal_dx »</TD></TR><TR><TD CLASS="quote">
have any pics? I'm thinking about mounting mine in the cowl where the wiper motor used to be, but I won't be able to see if it gets low...</TD></TR></TABLE>
ill see if he has any.... i would also try it out before you hide it to see if it is going to overflow
#3849
Re: (Coomer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Coomer »</TD></TR><TR><TD CLASS="quote">This thread is great...I just painted my partially-shaved bay last night...wouldn't be nearly as far as I am now if it weren't for H-T. </TD></TR></TABLE>
words are nothing without pictures!!!
#3850
Re: (SHG_EasyE)
we actually tried using the clutch resi on my freind's ek, it tended to overflow when going to full lock really quick, its not a large enough resivior.... i would try something a bit larger, or be careful not to put too much fluid in it.</TD></TR></TABLE>
I think the original vented power steering rack thread here on H-T showed a universal reservoir being used for venting purposes, but he did NOT put any fluid in the reservoir, probably because of those overflow issues you mentioned.
