Quick 9005 conversion question.
Old Mar 27, 2003 | 08:58 PM
jabroni95gsr's Avatar
Default Quick 9005 conversion question.
Not sure if this is the right spot, i guess changing bulbs classifies as appearance! Also with the archives down, i just need to make sure. With the 9005 conversion (high beam bulbs in low beam spot) in order to make it fit you need to do two modifications:
1) shave a bit of 1 of the 3 prongs that allow the bulb to click into place
2) inside the socket of the new bulb, shave/dremel away the two ridges so that it can be accepted into the 9006 connector.
Can someone please confirm this?
Old Mar 27, 2003 | 09:30 PM
NrG's Avatar
NrG
Default Re: Quick 9005 conversion question. (jabroni95gsr)
http://vmac.org/~weston/teg/9005conv/
Old Mar 27, 2003 | 09:32 PM
Default Re: Quick 9005 conversion question. (NrG)
thank you.
CNSK
Nov 8, 2004 06:58 AM
Train
Apr 8, 2004 06:51 AM
rollin_DC4
Apr 2, 2003 01:21 PM
