Just added some new parts to the dc2
Asr subframe brace, Blox lower control arms, Beaks lower tie bar, and a hood bra. All comments welcomed good or bad, thanks for looking.
Couldnt find the oem one so this is gonna have to do the job for now
Just finished throwing everything on so its a little dirty.
And the finish product
Re: Just added some new parts to the dc2
I've been debating on this with a couple of friends, but for some reason this color with that front doesnt catch my attention at all. Its still in the works though so who knows
I cant believe this ****, you're embarrassing the whole Honda community. Youd rather rock "pretty" brace stuff than to have your sway bar mounted with 4 bolts?
I wonder how long those Blox LCAs are gonna last... and you should probably bolt down your sway bar completely, don't wanna mess anything up I'm sure.
Clean it must be good to live in places like Florida and So Cal I gotta go thru winter and **** now I gotta wait till spring to put all my new stuff on
I was waiting for that, but i tried to bolt down the sway bar with all four bolts and no matter how i put it on only two were able to bolt up.. So, any suggestions?
you need different brackets. im using energy suspension. but i have a 22mm bar so im not sure what kind you would need.
Then when you have enough money buy an ITR/CTR rear sway bar and itll bolt on perfectly. 14mm sway bars dont need ASR braces to work.
This thread is a facepalm.
Made this for you OP. Take it as a gift from Arthas in CA.
Yeah I have a suggestion. Remove your ASR and your Beaks bar then reinstall your sway bar properly.
