How to install wings west lip on 94-97 integra?
Old 04-05-2003, 08:54 AM
Audio28's Avatar
Default How to install wings west lip on 94-97 integra?
Well I just got my lip back from the shop and I'm ready to install it. The question I have is. Do I keep the stock bottom lip, and put the wings west lip over it? Or do I remove the stock bottom lip? Thanks
Old 04-05-2003, 09:44 AM
PhatboyNYC's Avatar
Default Re: How to install wings west lip on 94-97 integra? (Audio28)
You put the WW lip on top of the stock lower valence of the bumper. Check out http://www.wingswest.com and you can check out the installtion instructions there.
[Modified by PhAtBoY Si, 3:34 PM 4/5/2003]
Old 04-05-2003, 10:14 AM
Type Wah's Avatar
I just got mine installed... it totally replaces ur stock lip, it should bolt right up!
Old 04-05-2003, 10:18 AM
PhatboyNYC's Avatar
Default Re: How to install wings west lip on 94-97 integra? (Type Wah)
I've had the WW RS lip on my teg too and it DOESN'T replace the stock lip, it goes on top of it.
Old 04-05-2003, 10:21 AM
Type Wah's Avatar
Default Re: How to install wings west lip on 94-97 integra? (PhAtBoY Si)
u serious? well mine bolted right up in place of my stock lip.. I have the WW RS II, i'll post pics when i get a chance...
Old 04-05-2003, 10:47 AM
Audio28's Avatar
yeah, i have the rs too w/o the vents. so i guess i'm gonna try to install it w/o the stock lip. What do I use, it doesn't look like i can use screws. How did you install it, did you use two-sided tape and what kind?
[Modified by Audio28, 7:50 PM 4/5/2003]
Old 04-05-2003, 10:49 AM
vtecdc2's Avatar
the type I goes over the stock lip. the type II replaces.
Old 04-05-2003, 10:51 AM
Type Wah's Avatar
when you remove ur stock lip, there will be bolts that hold it up, and on the lip there will be a clip with thread for the bolt to screw in, I removed those clips and clamped it into my ww lip, then bolted it right on. I wish I had a picture to show you... maybe someone else can explain better..
Old 04-05-2003, 11:37 AM
PhatboyNYC's Avatar
Default Re: How to install wings west lip on 94-97 integra? (VTECDC2)
Ok I just checked the WingsWest site and he's right. The WW RS lip goes over the stock lower valence while the WW RS II lip replaces the lower valence.
Old 04-05-2003, 11:57 AM
Audio28's Avatar
thanks for the help guy!!
wow_ohoh
06-12-2009 12:08 AM
BAMA4792
07-21-2007 07:18 PM
shutta
03-18-2006 01:09 PM
wpgcivic
10-23-2004 08:20 AM
riack
06-20-2002 11:32 AM
Quick Reply: How to install wings west lip on 94-97 integra?
