Couple new shots of the DC
Re: Couple new shots of the DC
The subframe brace is made by BWR. Going to try and get the sideskirts painted this weekend if it is nice out. Can't wait for tax returns, I would like to pick up a set of Sprint Hart's.
Thanks for all the comments guys, much appreciated.
I like them alot. I just wish that the gold subframe brace matched the LCA's a little better color wise. On the rear subframe brace, I had to use washers where the top bolt mounts the rear sway. There was about a 1 inch gap between the bracket and the brace. I used a fairly large nut to make up the difference and it works fine. You might run into this same problem too when mounting yours, not sure if they have fixed this problem yet at BWR.
