cleaning windows!
cleaning windows!
either i really suck, or i need help.
i hate trying to clean my windows, because all i evcer get is streaks.
whats the best product you have ever used to really clean the **** outta windowS?
Re: cleaning windows! (buh_buh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buh_buh »</TD></TR><TR><TD CLASS="quote">just windex and newspaper </TD></TR></TABLE>
Re: (ECAhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECAhatch »</TD></TR><TR><TD CLASS="quote">im gonna try this newspaper **** sometime....</TD></TR></TABLE>
you probably shouldnt use ****, i doubt that it will make your windows any cleaner
i use some foam window cleaner, i cant recall the name. but i use that with paper towels and it never leaves streaks. the glass cleaner is a black can and a yellow top, i dont recall the name. but it works great.
Re: (CypressGreenLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CypressGreenLS »</TD></TR><TR><TD CLASS="quote">Stoners Invisible Glass/ use MicroFiber Cloth </TD></TR></TABLE>
sometimes Ill use wax on my glass after the invisible glass, just a little... that usually gets rid of any left over streaks and it makes it easier to clean up bugs/bird **** in the future.
the son and the heir
Re: cleaning windows! (GreenMachineRex)
heres a secret that i learned. for the outside anything will get the windows clean without streaks. but for the inside where it's harder to clean because of the mositure that we exhale, i found out the best way to clean is to do it in two steps:
1) first clean the window with either glass cleaner or just a wet rag and water.
2) while it is still moist, use a clean towel with some abrasion to it, like a lower quality bath towel and wipe it dry. you have to use a bit of force and wipe until the window is completely dry. the towel is the key in getting the oil and streaks removed.
Re: (batmang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batmang »</TD></TR><TR><TD CLASS="quote">i use some foam window cleaner, i cant recall the name. but i use that with paper towels and it never leaves streaks. the glass cleaner is a black can and a yellow top, i dont recall the name. but it works great.</TD></TR></TABLE>
thats Stoners invisable glass
Re: (Nubz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nubz »</TD></TR><TR><TD CLASS="quote">newspaper works wonders. also was told by guys at mothers to use vinegar and water.</TD></TR></TABLE>
Use Hot water and this works great. I smoke in my car and the windows get real nasty inside and this always does the trick.
Re: (VisPreludeVtec)
the GM goodwrench glass cleaner is effing amazing. thats what we used at BMW when i worked there.
clean it like you normally would, and then take a dry rag and clean it again. we use diapers, they work very.
moleodonuts
20
06-26-2004 07:49 AM
