2000 front conversion
Old Nov 5, 2005 | 05:27 PM
trick_db's Avatar
Default 2000 front conversion
well i got a 98 honda civic. i bought it from my friend.. but from what i see on ht.. most of the conversion i seen so far look good. but the grill on my 2000 front doesnt seem like it fit perfectly. what is wrong? plz help.
Old Nov 5, 2005 | 05:31 PM
WERD up's Avatar
Default Re: 2000 front conversion (trickek9)
i think you have to change your whole front end to a 2000 front end, but what would i know
Old Nov 5, 2005 | 05:35 PM
John in NorCal's Avatar
ask this guy?
https://honda-tech.com/zerothread?id=1007465
Old Nov 5, 2005 | 06:12 PM
trick_db's Avatar
Default Re: 2000 front conversion (werd_up)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by werd_up &raquo;</TD></TR><TR><TD CLASS="quote">i think you have to change your whole front end to a 2000 front end, but what would i know </TD></TR></TABLE>
everything is 2000.. just that the grill didnt match up correctly you can see it slightly off
Old Nov 6, 2005 | 02:56 PM
HCRX311's Avatar
show some pics. aftermarket or oem?
Old Nov 6, 2005 | 04:26 PM
BRICKHEAD's Avatar
If the lines on your hood dont match up with the lines on your grill then your grill is wrong. Get the 99 2000 grill and everything is all good. That would be my guess not seeing any pics.
Old Nov 6, 2005 | 05:16 PM
DxBurnoutKing's Avatar
Default Re: 2000 front conversion (John in NorCal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by John in NorCal &raquo;</TD></TR><TR><TD CLASS="quote">ask this guy?
https://honda-tech.com/zerothread?id=1007465</TD></TR></TABLE>
Sup??
Click on the link in my sig if you wanna see what happens when thieves steal your **** then try to raise a 99-00 front end conversion up from the radiator support.
Old Nov 6, 2005 | 05:38 PM
...emu...'s Avatar
Default Re: 2000 front conversion (DxBurnoutKing)
Old Nov 6, 2005 | 05:40 PM
The_Todd's Avatar
Farts in the shower
96-98 is completely different than 99-00...
If you want to swap to 99-00 style you need rad support (or modify the 96-98), fenders, bumper and headlights (grill too but you already have that).
Old Nov 6, 2005 | 05:43 PM
ff terror's Avatar
too old for school
Stay 96-98 dude... buy my JDM SIR bumpers and a SIR lip and it'll be 10 times sicker than a 99+ conversion.
http://hondamarketplace.com/zerothread?id=1418726
Old Nov 6, 2005 | 06:45 PM
808_si's Avatar
Default Re: 2000 front conversion (ff_terror)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ff_terror &raquo;</TD></TR><TR><TD CLASS="quote">Stay 96-98 dude... buy my JDM SIR bumpers and a SIR lip and it'll be 10 times sicker than a 99+ conversion.
http://hondamarketplace.com/zerothread?id=1418726</TD></TR></TABLE>
+1
Old Nov 6, 2005 | 08:17 PM
trick_db's Avatar
Default Re: 2000 front conversion (.ken)
i got everything 99-00? but what do i need to do to the radiator supporT?
Old Nov 6, 2005 | 08:19 PM
trick_db's Avatar
Default Re: 2000 front conversion (BRICKHEAD)
everything is fine.. is just that the grill have like a lump, but on the driver side it fit perfectly.. for some reason on the passenger side it dont wanan go thru.. i think the tab on the bumper is being force out by the radiator support. i might take a look at a friend car.
Old Nov 6, 2005 | 11:14 PM
trick_db's Avatar
Default Re: 2000 front conversion (sleepyzze110)
yea i think thats the reason why, i was looking at some website on ht.. this guy had to cut out the tab and drill 2 holele..i think thats the reason why.
http://www.mestiso.net/forums/...ic=60
Old Nov 7, 2005 | 12:29 AM
NrG's Avatar
NrG
you guys are going to hear this once. I said it many times before. 96-98 and 99-00 are both the same rad support. The only different are a few mounting holes. The problems that people are getting are from the Bumper retainer brackets. the 96-98 and 99-00 are completely different. The retainer is that metal bracket that sits right below the headlights.
trickek9, I believe you PM me about this. Your problem is your grill. You must mount it FLUSHED on the bumper first. there are bolts that hold it on. then slide the bumper onto the car, make sure the bumper clips over the retainers, then slides on like normal. then mounting the bolts on the fenders.
DxBurnoutKing, um.. your conversion is pretty ghetto man. you didn't weld it. looks like you used self taping screws.
look, no weld marks. nice rust from not doing it correctly.
btw, this dude did it correctly. just need to cut this tab, line up the bumper and drill a hole. then put in a plastic retainer clip.
Modified by NrG at 1:45 AM 11/7/2005
Old Nov 7, 2005 | 05:04 AM
^^ yea it wasnt my car... and i figured that my boy would go and get it welded... but oh well. it held up just fine until the thieves who stole it tried jacking the car up by that point and then the flatbed dropped the car on its frame in the junkyard.
Old Nov 7, 2005 | 06:07 AM
Spoogen_1's Avatar
omg u gotta be kidding me. the hood, grill bumper, fenders, headlights are differnt. thats why
Old Nov 7, 2005 | 06:50 PM
mestizo's Avatar
Default Re: (NrG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NrG &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by NrG at 1:45 AM 11/7/2005</TD></TR></TABLE>
LOL thats my car from this past weekend if u want my DIY on this its here
Also I agree that not spot welding the rad support back on was wrong which i noticed on that old thread too, plus the fact that they used a "SAWZALL" freaked me out, since all u need is a spot weld removal bit and then an air chizel to just bump the support off with out damaging anything. But too each their own u know... but its possible to do it without the rad support as you can see by my results, they would have been a lot better if i had used honda parts too.
here is a pic if you dont go to my DIY link
Old Nov 8, 2005 | 01:52 PM
trick_db's Avatar
Default Re: (DxBurnoutKing)
thnx alot bro. sick *** shiet
need 99-00 headlight? ya fealous got that ****?
Old Nov 8, 2005 | 04:43 PM
yee SERIOUS's Avatar
oooohhh...i wanna do one. hahaha. maybe if i get my gf's car here from the east coast.
Old Nov 8, 2005 | 05:31 PM
ekcivic9's Avatar
i read somewhere last time that in a 96-98 theres more room for a bigger radiator?
EK_Project97
Feb 10, 2012 02:41 PM
NOFX
67
Feb 1, 2012 07:06 AM
reyrey2006
16
Jul 29, 2008 10:19 PM
Civic2Integra
Jan 22, 2007 08:54 PM
