* POST Your J Swap Pics Or Any J series Swap *
Old 09-16-2013, 05:14 PM
  #301
Spoolinls's Avatar
Default Re: * POST Your J Swap Pics Or Any J series Swap *
Here is my work in progress
Old 10-15-2013, 08:11 AM
  #302
Widmest's Avatar
Originally Posted by jry2598
Hands down my J swap was more fun to drive than my K20 swap....
i know this is old but what intake mani are you runnin
Old 10-17-2013, 10:06 PM
  #303
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
I love the j swap but you guys are doing it all wrong!!! It was meant to be a rear engine rwd. I can't wait for my wife to finish nursing school and then I will be putting a j in the back of my civic hatch!!! Has this not been done yet????
Old 10-17-2013, 10:30 PM
  #304
Mr Envy's Avatar
has been done before aswell as j series north south in a civic and s2k. even a rwd c series civic
Old 10-18-2013, 08:48 AM
  #305
Bouckaroo's Avatar
there have been multiple rwd j swaps, from insights to civics, from 5 speed to six speed to paddle shifting.......
Old 10-18-2013, 02:45 PM
  #306
All the one I have seen are front engine rwd. I have only seen one mid engine j swap and that was on a blue ef hatch.
Old 10-19-2013, 03:27 PM
  #307
PinkBatman's Avatar
Here is the Insight
Old 11-12-2013, 01:56 PM
  #308
jry2598's Avatar
J35A4 Honda Odyssey intake manifold proted and custom Q45 throttle body 3.5 inch intake.
Old 03-26-2014, 04:16 PM
  #309
PinkBatman's Avatar
Bump, I'm sure there are some more of these around now.
Old 03-26-2014, 05:53 PM
  #310
Spoolinls's Avatar
I will have some more when my turbo manifold is done
Old 03-26-2014, 10:34 PM
  #311
EKSedAndy's Avatar
Originally Posted by Fnix
Running 17's would help alot and eliminate the oil pan issue?
Originally Posted by dfanatic
Absolutely. If you want a closed hood on one of these swaps every inch counts.
Rim size has nothing to do with ground clearance as long as you are running properly-sized tires. For example, a 205/55R15 has about the exact same diameter as a 215/40R17. If you want to gain ground clearance you can go to a larger diameter tire in any rim size.
Old 03-27-2014, 02:13 AM
  #312
P-M-B,93EXsedan's Avatar
Its nice to see ppl using intake manifolds instead of holes in their hoods now.
id really like to have a 4WD hatch with a J in the back. That'd be ****** nasty fast, 15,000 rpms in a civic
Old 03-27-2014, 02:15 AM
  #313
Where are people getting their 6speeds tho? I keep seeing prices around 1,200. I need a full trans swap tho, harness computer pedals transmission shifter etc etc. My 04 accord's automatic is very sad.
Old 03-29-2014, 04:20 PM
  #314
flatblack-h22's Avatar
Old 03-30-2014, 09:40 AM
  #315
PinkBatman's Avatar
Lots of tranny info here
Most of us are doing the entire swap though, which is a little bit easier than converting an auto Accord.
Old 03-30-2014, 12:11 PM
  #316
Fnix's Avatar
So what are most of these civics with stock J swaps running in the quarter? 13's?
Old 03-30-2014, 12:55 PM
  #317
no one wants to hear the truth
cetcivic's Avatar
The potato-est post of 2014
Old 03-30-2014, 10:20 PM
  #318
Scotty Dosent Know's Avatar
Would love to put a J swap in my 98 CR-V. Would probably get about the same MPG with a ton more get up and go.
Also IM to hood clearance wouldnt be a problem, the CR-V has a ton of room above the motor.
.......Hmmmmm
Old 03-31-2014, 12:03 AM
  #319
if I'm gonna swap a J into the back of a civic, why wouldn't I leave the stock motor up front too?
I bet it would **** all over a NSX. It would even be lighter.
Old 03-31-2014, 12:11 AM
  #320
thank you. IV been waiting for a rear end totaled accord 6-6 to show up in a u-pull yard in NJ.
it sucks cuz lots of ******** are like "oh we can get u a tranny but were gon a charge you 250 more than we paid"
then I tell em to get me the ECU, harness, pedals, shifter, everything, then they act dumb and i insist they tell me if they have a car or not and they're too dumb to understand i need to rape a 6-6 accord and i would rather do it myself.
edit. Atleast I have sum civic to play with in the mean time. I think I'm just gonna b swap my dx coupe, boost it and sell it. Then bring my accord to Paul. He pretty much told me I cant do it myself, but I still wanna try. I'll still probably only be able to get the parts, do the clutch job etc, and leave the body harness wiring/immobilizer hacking to him.
Old 03-31-2014, 04:33 PM
  #321
j.red's Avatar
No.
You have no idea what it takes to synchronize 2 engines together to the point where you can effectively run two totally separate drive lines in one car. That and by the time you're done adding all that weight of a j series in the back IN ADDITION to what's already there, you're going to not only be heavier than an nsx, but far more out of balance than one.
I don't even know why I'm taking the time to try to reason with this post...
Old 07-14-2014, 09:46 PM
  #322
PinkBatman's Avatar
Bump for more big block cars!
Old 08-17-2014, 09:25 PM
  #323
Fish Twig
tony_2018's Avatar
Hey this link is dead.
Old 08-17-2014, 10:14 PM
  #324
Fish Twig
tony_2018's Avatar
This is exactly what I did. BUT no hood shimming.
gen2 Hasport mounts on the higher setting
3.7 TL SH AWD upper manifold
Shimmed the passenger and driver mounts 1/2 inch
Cut some hood skeleton and done.
Didnt have to shim the hood at all either and oil pan clearance is decent. This was on a DC2. The car also uses 17" CCW LM12s. The 17 inch wheel size keeps a decent stance while still keeping good ground clearance. Dont even attempt to do this with a 15" wheel. May as well go to the higher setting and cut a hole in the hood if you do. 16" will work if you rock a decent amount of rubber. I had an even harder time making all this work than most since this car has a triptronic tranny and required custom trans mounts and a secondary torque mount. BTW this is the same car as the orange one pictured above. This is the new look.
I know this may be about yr ago when you posted those, how is the ground clearance for this integra swap?
Old 08-18-2014, 01:24 PM
  #325
PinkBatman's Avatar
Sorry, j32a just changed software so lots of the old links are now broken.
I assume this is the thread I linked.
Quick Reply: * POST Your J Swap Pics Or Any J series Swap *
