Drivers door lock problems
I have a 2 door 2003 Honda Accord EX.
Problem:
1)The remote key will NOT lock or unlock the doors (but I do hear a clicking sound near the fuse box when i use the "unlock button" & when I hit the "lock button" I hear a click sound on the passenger door side, but not the drivers side.)
Therefore I was using the key manually to open the drivers side door, which now when I put the key into the outside door lock, the key will not even turn. So, now I have to keep the doors unlocked in order to get into my car.
The Alarm still works if I manually lock the doors from the inside by pressing down the lock *****.
The Trunk release button still works on the remote.
What is the problem & what needs to be replaced?
*first the Remote key does not lock or unlock the doors & Now, the outside drivers door lock is jammed(key will go in, but not turn).* Please help!
Problem:
Re: Drivers door lock problems
You know that the key lock doesn't work so start there. You're going to have to rip the whole door apart to get to it.
Could be the cylinder or the switch. #28 or 39
http://www.hondaautomotiveparts.com/...-+OUTER+HANDLE
i have a 99 accord EX, my drivers door wont lock or unlock with the switch or the keyless entry.. i have to manualy lock it or use the key and also when i lock with the key or switch, the keyless entry WON'T unlock any door.
These links show videos on remove the door panel.
http://www.youtube.com/watch?v=Uxq4z7NRV0c
http://www.youtube.com/watch?v=LV4FZKNKfjk
Normally, after the panel is removed, the actuator is held on to the latch with a few screws. There may be other parts that need to be removed to give you easier access to the actuator (if it turns out to be the actuator).
condor22
01-23-2019 09:16 AM
