Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2004 Honda Accord Spark Plugs Q.
Old 06-30-2011, 02:36 PM
EDD512's Avatar
Default 2004 Honda Accord Spark Plugs Q.
My Accord has 105k miles on it.
Just bought these " NGK Laser Iridium Premium Spark Plugs",
Model Type: IZFR6K11.
Car: V4. 4Dr. Honda Accord.
Did I get the correct ones?
Thanks.
Old 06-30-2011, 02:44 PM
redbull-1's Avatar
Default Re: 2004 Honda Accord Spark Plugs Q.
Those are correct as long as your car is not the California model.
Btw: your engine is known as an L4 or I4. It's not a V.
Old 06-30-2011, 02:50 PM
redbull-1's Avatar
Also, when installing the NGKs, don't use anti-seize on them.
http://www.ngkplugpro.ca/content/con...SparkPlugs.pdf
Old 07-01-2011, 05:18 AM
riprocop's Avatar
Enlighten me on the California model? I live and bought my Accord brand new in S.Cal. I looked up the make and # of the oem spark plugs and they weren't cheap. I need to change them out now, it has 104k miles.
Old 07-01-2011, 06:27 AM
redbull-1's Avatar
California had stricter emissions standards than many other states. For California (and a few other states), the Honda Accord had slight differences to meet the PZEV (Partial Zero Emission Vehicle) emission standards. It's actually a little more involved than what I am stating.
For the California model, 4 cylinder which came with automatic transmission, the recommended NGK spark plug number was IZFR6K13.
Other 4 cylinder Accords (I didn't check if the V6 was the same) used NGK IZFR6K11.
The difference in the spark plugs were mainly the plug gap, as the last number on NGK plugs refers to that. The NGK plugs for the California model had a slightly wider gap.
http://www.ngksparkplugs.com/techinf...tnumberkey.pdf
The higher costs for the spark plugs are due to them being iridium. They have a longer service life and you do not adjust the gap on iridium plugs; so, as not to risk damaging the electrode.
As far costs between NGK IZFR6K11 and IZFR6K13, there should be no difference.
Old 07-01-2011, 12:57 PM
EDD512's Avatar
Thanks. By V4, I meant a 4 cylinder.
The spark Plugs cost me 60$ at an Auto Part store. At Honda they where 130$. Ebay has them for a much cheaper price at about 30$.
I live in SoCal, so I have to check if its a Cali model. Is there any harm in using the IZFR6K11 model on the Cali accord?
Old 08-03-2011, 12:18 PM
stiffpeaks's Avatar
Is it difficult to reach and change spark plugs on a 2004 Accord V6? What is the proper NGC number plug to use?
Thanks for your help!
Old 08-03-2011, 02:11 PM
BLKFLSH's Avatar
Same number as the 4 cylinder. The NGK number is (IZFR6K-11) (if it's not a california model). If you want to use Denso plugs the number is (SKJ20DR-M11). The rear bank can be a challenge, if you don't have the right tools.
Old 08-27-2019, 07:19 AM
mdmm55's Avatar
Hi,
I found on this spark plugs in Forum about following, NGK Laser Iridium Spark Plugs
I am in Mississauga,Ontario and my car is Honda Civic 2012 , 4 doors,4 cylinder automatic,1.8 Liter .
Are above spark plugs best for my car and from where should I order online with free shipment,please.
Old 08-27-2019, 07:45 AM
shipo's Avatar
Originally Posted by mdmm55
Hi,
What plugs are listed in your Owner's Manual? Those are the best for your engine.
metrowerk
12-31-2018 03:59 AM
Johnnyrod310
07-08-2016 07:24 AM
kventura
02-26-2008 10:11 PM
13lue
07-25-2005 12:27 PM
raguripper
06-30-2003 03:58 AM
Quick Reply: 2004 Honda Accord Spark Plugs Q.
