Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
07 Accord Ex-L
Old 05-17-2017, 01:11 PM
vintagevirginia's Avatar
Default 07 Accord Ex-L
I just purchased 2 months ago and it is requiring a quart of oil every 500 miles.
Old 05-18-2017, 01:37 AM
eksine's Avatar
Default Re: 07 Accord Ex-L
If it's still under warranty talk to the manager at the dealership. Otherwise it would be pretty obvious where it came from. we need to know that before we can help you. If you still can't tell you need to clean off the top and bottom of the engine using brake cleaner or soap and water and a brush or a pad and then get back to us when you know where it's leaking from. If it's from the top it's probably the valve cover gasket. If it's from the bottom it could be the oil filter which should be pretty obvious. or it could be from the oil pan which would mean the gasket is got a hole in it. Tell us where it's leaking from
Mveilenstein
04-22-2018 05:25 AM
Mr_maxime
07-10-2016 08:04 PM
HndaOwner
05-10-2014 04:24 PM
sma_V6
01-17-2011 01:22 PM
Suke
01-06-2005 06:11 PM
Quick Reply: 07 Accord Ex-L
