07 Accord Ex-L
Re: 07 Accord Ex-L
If it's still under warranty talk to the manager at the dealership. Otherwise it would be pretty obvious where it came from. we need to know that before we can help you. If you still can't tell you need to clean off the top and bottom of the engine using brake cleaner or soap and water and a brush or a pad and then get back to us when you know where it's leaking from. If it's from the top it's probably the valve cover gasket. If it's from the bottom it could be the oil filter which should be pretty obvious. or it could be from the oil pan which would mean the gasket is got a hole in it. Tell us where it's leaking from
