Whats this part called??
Alright so I was in the process of changing the ac compressor but when I put in the new one, I noticed that it did not have this part the old one had. I tried taking it off the old one but that is not going to happen. I took it to autozone to ask them, but they are all clueless. If someone knows what the part is called or the part number, please let me know. It would be greatly appreciated. Thanks.
Re: Whats this part called??
That looks like the mount where the discharge hose goes in. I don't think that part is listed separately.
Look at the new compressor you have, you may not need it if there is a port for the discharge hose. Take a picture of the new one and post it.
Here is a link with instructions to adding AC that may help you: http://techinfo.honda.com/rjanisis/pubs/AI/AII25711.pdf
Not sure that you can get that sepearte as well...you can swap it to the new one unless the head of the screw is seized, once its off change the O ring and reinstall the screw...its just an extension so they do not have to redesign hoses with tight bends thats all
oh it sucks to figure that out after the new one is in. As far as that bolt goes if vise grips will not break it free, then dremel the head off and just slide tthe piece over it and replace that bolt on the new compressor.
Ummm Im pretty sure its hard to get the wrong item unless my brother ordered the wrong item or the company sent the wrong item lol, but Im pretty sure its the right one. Thanks though.
I would try a center punch and a hammer on the bolts. See this thread regarding the use of a center punch: https://honda-tech.com/forums/honda-accord-1990-2002-2/removing-map-sensor-stripped-screw-2750968/
If that doesn't work, my last resort would be drilling the bolts, starting with a very small drill bit. But, I would say the punch and hammer should work.
ummm at the dealership we never have to change that over so either you have the wrong compressor or your dealing with an aftermarket in that case its your fault.i have access to the honda catalog right now on any computer with an internet access.all i need is a vin and we can settle this.
This sounds very familiar, I believe the OP was in my shop looking for the same item. As stated, on a Honda compressor, this is not available separately, so he probably purchased either an aftermarket or an e-bay item.
Looks like a drill bit and ez-out....
Haha he probably was. He said he was going everywhere to find out. What shop, just wondering?
john666
09-07-2004 11:18 PM
