v6 clutch, can I use a 3.2 clutch or need 3.0?
My throw out bearing is noisy and the OEM clutch can't handle stock power, and it's only been 18 months....
Anyway, I had a Centerforce in my supra and prelude, loved it, but they only list for the 3.2....will it fit my 3.0?
Re: v6 clutch, can I use a 3.2 clutch or need 3.0?
I call the company and see if the 3.2 will fit your car.
I had to replace broken clutch and flywheel day 3 of ownership at 155k, now at 178k and the bearing is toast. I FINALLY got an answer from a different dealership today that the warranty is expired. So since I'm now a tech in a nice shop I'll just do it at work and make sure it's done right. I think they installed the old bearing.
Yes, you can go aftermarket for the clutch set up - pressure plate, disc, throw out bearing. pilot bearing and flywheel.
My question really was around the comment that the OE set up could not handle the OE power of the car.
The dealer tried to say my clutch fork was bad and causing it....no, it shifts buttery smooth. And quoted it for $1100 after I just had the work done. Why would they install a bad part?
Anyway, **** the dealer....DOES THE 3.2 CLUTCH FIT THE 3.0?
Of course. Nobody will give an answer to avoid potential liability if it doesn't fit or causes damage, hence why I came here to ask other enthusiasts who have frankensteined Hondas.
MikeMAN
02-21-2003 07:53 AM
