TCS Light
TCS Light
I thought I saw a thread for this before, but I couldn't find it now so I'm starting this one.
I have a 2003 Accord Coupe, 120k miles, V6 Auto.
My questions are fairly simple, how bad is it that my TCS light comes on almost randomly? What's making the light come on? How can I fix it & how much would that cost? and can this lead to a more serious problem?
Also if you've had this problem you can tell me what it has or hasn't done to your car, and how you dealt/are dealing with it.
Some quick examples: I can do some serious wheeling (semi-serious haha) and nothing, everything is fine. Sometimes I can be sitting at a stop light and it will come on. I can drive 12 hours to FL without it coming on, or it might come on before I get out of the drive way...
Thanks for the help guys...
Re: TCS Light
You most likely are having brake light switch issues. You can have this system diag. by the dealer or a good aftermarket Honda shop. You could scan your ECM for any temporary DTCs some powertrain DTCs will make the TCS do this also. Brake light switches are very cheap and easy to replace.
Re: TCS Light
Re: TCS Light
My issue was that the 3rd brake light was burnt out. I replaced and the TCS came on a few more times after the new bulb, but hasn't happened in months now.
Check ALL your brake lights.
Good luck!
Good luck!
Re: TCS Light
With out a DTC cant really help you with any issues. I would take it to honda and have it scanned. They can access any code in your car while other scan tools like auto zone wont have a clue.
Im betting though it is a intermittent sensor failure. Their are alot of sensors that are involved with the VSA system. And the Brake pedal sensor is one of them. So unless you want to save money and just start testing every sensor which some require taking out seats and moving carpet get it scanned and let us know what the code is and what your local dealer feels should be the correct action in fixing the issue.
Re: TCS Light
I'll say this, I have taken the brake switch out & cleaned it.. figured I'd try that before buying a new one.. & the TCS light has not come on since.. YAY!!!!
carbonfibersi
03-10-2005 02:57 PM
