Stressed
Moderator
Re: Stressed
The TSX is a K24A2, and yes, you can swap as long as you also swap computers, and the static compression ratio is completely different from the two as is the VTC cam gear settings, so tuning is needed if using anything other than the stock TSX ECU.
