starting trouble
starting trouble
2005 accord coupe ex-l v6
been having some difficulty getting it started the past couple of days.
Had the battery tested at honda to make sure that's not the problem and the results came back fine. connection is clean and tight.
here are some videos to explain.
http://www.youtube.com/watch?v=pVqd4LlBztg
http://www.youtube.com/watch?v=E4pQHbenZko
http://www.youtube.com/watch?v=3ji3v1ZzPNc
Re: starting trouble
there could be a different possibility. the way the car is starting.. the battery definately sound goood. couple of question i would like to ask is. is this on everystart? intermittent?
does the car eventually catches and than shut off? there is a bullentin about the accord fuel pump relay.. i would look into that.. maybe swapping the relay with another one in the car and retest and go from there.
the dash lights shouldn't flicker like that.. its got to be something w/ either the ignition switch itself or a ground. Wish i could help more, but heres a bump for you at the very least..
did u try what i said?
ty.s07
12-24-2011 11:50 AM
