Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
low brake fluid/fluid found at rear parking brake area
Old 12-20-2014, 04:14 PM
mikegarcia2000's Avatar
Default low brake fluid/fluid found at rear parking brake area
Hi Everyone,
The brake light was staying on in my wife's 2005 Honda Accord. I checked the brake fluid and it was really low. The first thing I did was pop the tires and look at the pads. It hasn't been too long since I changed the pads and they looked fine. Definitely not low enough to cause the reservoir to be as low as it was.
So I started inspecting the master cylinder and system for leaks. The spring area of the rear passenger side parking brake has fluid. It didn't look like a leak from the caliper, just fluid where the parking brake engages.
So, there was fluid on the spring and bolt in the image above and below the spring.
Any idea what might be going on? The brakes seem to work fine and the parking brake works fine. The leak seems to be a very slow leak.
Thanks,
-Mike
Old 12-21-2014, 10:53 AM
DCFIVER's Avatar
Default Re: low brake fluid/fluid found at rear parking brake area
Looks like the caliper. Remove it and check. Or have someone pump the brakes while you are back there looking for a leak....
Old 03-29-2015, 02:52 PM
clifffarrar's Avatar
The parking brake is part of the rear caliper with seals around the actuating mechanism. Caliper needs to be rebuilt or replaced.
joe6
03-20-2011 07:39 PM
St3v3
01-02-2008 04:52 PM
Balut
02-24-2005 08:31 PM
Understeer
11-30-2003 10:28 AM
Quick Reply: low brake fluid/fluid found at rear parking brake area
