Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Hand Break & TCS Indicators On (2003 Accord Coupe V6)
Old 10-10-2011, 06:37 AM
atom1's Avatar
Default Hand Break & TCS Indicators On (2003 Accord Coupe V6)
Hello Folks,
I need some help here with my Accord Coupe 2003 V6.
The Hand Break light is on lately whenever the car is started and it stays on all time, even though the Hand Break is not in use. Also, as soon as the HB light is on, the Traction Control System (TCS) would come up right after.
I have been told this could be the Hand break switch not functioning properly for some reason that in turn causes the TCS light to go on as well, and the only way to check it out is to open the console in that area.
If this is the case, can someone please advice me how to open the console in the Hand Break area?
Thanks so much!
Old 11-10-2011, 05:38 PM
holmadk's Avatar
Default Re: Hand Break & TCS Indicators On (2003 Accord Coupe V6)
Make sure you have enough brake fluid in the master cylinder. also try to turn the car off and unplug the float switch thats in the master you will see a small two pin connector that is pluged into the master cylinder resivour after you unplug it start the car, if the light goes off and stays off you need a new master cylinder or just leave the connector unpluged.
Old 11-22-2011, 06:51 PM
HNDA_4SHOOR's Avatar
^ start from this
elletrain82
11
07-06-2011 02:23 PM
sh0rt1e67
05-03-2009 07:58 PM
oths88
05-24-2007 12:44 PM
TypeR#1049
05-02-2007 01:28 PM
Quick Reply: Hand Break & TCS Indicators On (2003 Accord Coupe V6)
