Gauges quit
Re: Gauges quit
Cause could me one or more things. There is some loss of communication going on. ECM/PCM, connector, or wiring are some possible culprits. Take a look at the ECM/PCM located under the center console. See if there is any leakage from a blocked up A/C evap drain hose onto the ECM/PCM.
Re: Gauges quit
Thanks for your response. I look at ecu and no issues with leaks.
gauges quit only when hot out during the day(i am in florida)after 10 minutes of driving.
I can turn off ,start it back up and everything will be fine for a while. And then they will quit again.At night no problem.
all gauges but fuel gauge die .blower will work but no compressor..
Appreciate your help
